[QGIS-Developer] Building pyqgis doc locally
matteo
matteo.ghetta at gmail.com
Tue Dec 13 00:58:48 PST 2022
> you might need to copy the folder, same than for _templates:
> see https://github.com/qgis/pyqgis/search?q=_templates
> <https://github.com/qgis/pyqgis/search?q=_templates>
this approach seems working (at least locally). I've made a PR:
https://github.com/qgis/pyqgis/pull/101
Cheers and thanks for the help
Matteo>
> otherwise, look at https://github.com/qgis/pyqgis/pull/89/files?w=1
> <https://github.com/qgis/pyqgis/pull/89/files?w=1>
> Le mar. 13 déc. 2022 à 09:12, matteo <matteo.ghetta at gmail.com
> <mailto:matteo.ghetta at gmail.com>> a écrit :
> Hi Denis,
> > yes you can limit what you build
> > see
> https://github.com/qgis/pyqgis/blob/master/scripts/build-docs.sh
> <https://github.com/qgis/pyqgis/blob/master/scripts/build-docs.sh>
> <https://github.com/qgis/pyqgis/blob/master/scripts/build-docs.sh>>
> > either use --package core/gui/… or --class QgsVector (which will
> work as
> > QgsVector*)
> thanks, it works as expected!
> Last (hopefully :) ) question: I'm adding some custom css in the
> _static/css/custom.css file. I've also added:
> html_static_path = ['_static']
> html_css_files = [
> 'css/custom.css',
> in the conf.py.in <http://conf.py.in> file, but when compiling
> sphinx is complaining:
> WARNING: html_static_path entry '_static' does not exist
> Do you have any idea why this is happening?
> Cheers and thanks again
> Matteo
> > > Another approach is to do a PR on the repo, you will have
> a built
> > > example at https://qgis.org/pyqgis/master_PRXX
> <https://qgis.org/pyqgis/master_PRXX>
> <https://qgis.org/pyqgis/master_PRXX>>
> <https://qgis.org/pyqgis/master_PRXX>>> (replace XX) when it's finished.
> > and this can be done also to the forked repository right?
> > you would need to enable the pages on your repo, I am not sure
> this will
> > work out-of-the-box.
> > > I believe it would require a bit of love to improve this
> workflow
> > and
> > > drop the gh-pages branch.
> > > I hope this helps a bit.
> > Thanks Denis
> > Matteo
> > > Cheers,
> > > Denis
> > > Le mar. 13 déc. 2022 à 08:14, matteo via QGIS-Developer
> > > <qgis-developer at lists.osgeo.org
> <mailto:qgis-developer at lists.osgeo.org>
> <mailto:qgis-developer at lists.osgeo.org>>
> <mailto:qgis-developer at lists.osgeo.org>>>>
> > > a écrit :
> > > Hi devs,
> > > I've some small ideas to enhance the readthedocs theme
> of the
> > pyqgis
> > > documentation and I want make some local test before
> making a
> > pull
> > > request.
> > > I've cloned this repository (around 7GB?!):
> <https://github.com/qgis/pyqgis> <https://github.com/qgis/pyqgis
> <https://github.com/qgis/pyqgis>>
> <https://github.com/qgis/pyqgis>>>
> > > and then I followed the instruction of the Readme
> file. It seems
> > > building but it is literally taking ages (./build-docs.sh
> > > -qgis-build-dir /home/matteo/dev/qgis-master/).
> > > Am I doing something wrong or can I use some shortcut to
> > build it? I'm
> > > just playing with some css and eventually the
> config.py.in <http://config.py.in>
> > <http://config.py.in <http://config.py.in>>
> <http://config.py.in <http://config.py.in>>> file.
> > > Cheers and thanks for any advice
> > > Matteo
> > > _______________________________________________
> > > QGIS-Developer mailing list
> > > QGIS-Developer at lists.osgeo.org
> <mailto:QGIS-Developer at lists.osgeo.org>
> <mailto:QGIS-Developer at lists.osgeo.org>>
> <mailto:QGIS-Developer at lists.osgeo.org>>>
> > > List info:
> > https://lists.osgeo.org/mailman/listinfo/qgis-developer
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>>
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>>>
> > > Unsubscribe:
