[QGIS-Developer] Symbology of vector layer change while opening in lower version.
Nyall Dawson
nyall.dawson at gmail.com
Mon Dec 19 16:17:29 PST 2022
On Sun, 18 Dec 2022 at 12:19, Paul N via QGIS-Developer
<qgis-developer at lists.osgeo.org> wrote:
> I had created a project in 3.28 version with symbology of line and area. I havnt check with point layer.
> While opening the same project in lower version 3.16, 3.22, 3.26 the symbology of line become black and polygon fill become blue.
QGIS officially doesn't support opening newer documents in older QGIS
versions -- that's why you get warnings when you attempt to do this.
Suffice to say that this isn't considered a bug and was actually a
change made intentionally.
Nyall
> Is any problem or change in newer version.
> Regards
> Paul N
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
