[QGIS-Developer] prepare_commit.sh freezes console
DelazJ
delazj at gmail.com
Fri Dec 30 00:47:25 PST 2022
Hi Even,
Obviously, I didn't try that one. So simple and clear once explained.
Merci beaucoup,
Harrissou
Le ven. 16 déc. 2022 à 08:37, Even Rouault <even.rouault at spatialys.com> a
écrit :
> Hi Harrissou,
> "q" should do it, as the diff is displayed with the "less" utility, and
> it's the shortcut to exit from it
> Even
> Le 16/12/2022 à 06:18, Delaz J via QGIS-Developer a écrit :
> > Hi,
> > Whenever I run prepare_commit.sh and there are changes, I fail to find
> > how to get back to the command prompt. Whatever I do (and I can be
> > quite inventive on keyboard shortcuts), nothing more will happen in
> > the tab of the terminal I ran the command. The only option I have is
> > to kill that tab and continue in a new tab.
> > So my question is: How do you take control of your terminal after you
> > run prepare_commit.sh?
> > I'm on Ubuntu 22.04 if it makes any difference.
> > Thanks,
> > Harrissou
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221230/ceed3f48/attachment.htm>
