[QGIS-Developer] Pip install not working within QGIS with OSGeo4W v2?
tijan49 at yahoo.fr
tijan49 at yahoo.fr
Wed Jan 26 23:16:55 PST 2022
Hi Axel and list (I'm not sure my message are published on the list and
I don't know why ...)
I tried again with distinct version and this is my results, on Windows 10 :
- 3.16 (Installer = QGIS-OSGeo4W-3.16.15-1.msi) => fail
- 3.18 => (Installer = QGIS-OSGeo4W-3.18.3-1-Setup-x86_64.exe) => success
- 3.22 => (Installer = QGIS-OSGeo4W-3.22.2-1.msi) => fail
The error message is :
/" WARNING: Retrying (Retry(total=3, connect=None, read=None,
redirect=None, status=None)) after connection broken by 'SSLError("Can't
connect to HTTPS URL because the SSL module is not available.")':
/simple/xlsxwriter/ "/
_*The common point of the "fails" is the "msi" installer ... *_
Hope this tests can help to see better where the problem is ?
Axel : did you find a solution, or a workaround ?
Thanks to all.
Jean
Le 18/01/2022 à 23:05, Alexandre Neto a écrit :
> Use one of the qgis-full metapackages.
> A terça, 18/01/2022, 21:06, Axel Hörteborn
> <axel.n.c.andersson at gmail.com> escreveu:
> Thanks for checking as well Jürgen,
> Interesting that it worked for you, I just tried and deleted my
> osgeo4w folder and got a fresh copy of qgis3.22.3 (during the
> installation I only installed "qgis: QGIS Desktop" and
> "python3-pip") and the same result could it be that I need to
> install some more stuff to get it to work?
> Best regards
> Axel
> On Tue, 18 Jan 2022 at 15:52, Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi,
> On Tue, 18. Jan 2022 at 14:40:50 +0100, Axel Hörteborn wrote:
> > Is there anyone else that can share some light on this issue?
> > I've tried to make several changes to my qgis.bat and some
> other bat files
> > but I have no proposal how to fix it. Is this an intentional
> or accidental
> > change between OSGeo4w (v1) and OSGeo4w (v2)? (Shall I
> rewrite my plugins
> > or can I hope for a fix?)
> Works for me both in a fresh osgeo4w v2 install and QGIS
> 3.22.3 standalone (for
> reportlab - matplotlib and psycopg2 are already included anyway).
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel.
> +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
> +49-4931-918175-50
> Software Engineer D-26506 Norden https://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef
> on Libera|OFTC
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220127/82fffc5e/attachment.html>
