[QGIS-Developer] Vector Tiles in QGIS: throws "Error loading style: Style not found in database" with 'optional style url'
Richard Duivenvoorde
rdmailings at duif.net
Mon Jul 18 03:27:21 PDT 2022
Ok, just found out: the layer is not loading IF there is NO other (xyz?) layer.
So when it is the first layer you load, it will give the warning and NOT show anything.
If you already loaded some other layer (for example OSM xyz), THEN all is fine
I'll create an issue for it... wondering if there is some simple global vector tile server which has the same issue, so it is easier to reproduce...
Regards,
On 7/18/22 10:07, Richard Duivenvoorde via QGIS-Developer wrote:
> Hi People,
> Just playing with pg_tileserv, to check if QGIS was able to load tiles from it with a small data set, I fail to load because:
> "Error loading style: Style not found in database".
> Though in the connection dialog it says that the Style URL is Optional...
> Am I missing something? Tried with a fresh profile.
> Or is there some generic url I should/could use?
> (have to dive into these styling url's, to create one...)
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
