[QGIS-Developer] Is there a recommended way to include external Python packages
Gerald Kogler
geraldo at servus.at
Thu Jul 21 14:12:13 PDT 2022
Thanks for your recommendations, with that in mind I'll go for the
option 2, shipping the 3rd party package with the plugin.
Till now I did that including the whl-file, but after looking at your
plugins I see the advantage of your code of adding the directory which
contains the library to sys.path and then doing an import (see
https://github.com/NationalSecurityAgency/qgis-datetimetools-plugin/blob/master/__init__.py)
On 21/7/22 19:33, C Hamilton wrote:
> Generally speaking it is not recommended, but I have done it with
> several of my plugins (KML Tools, Date/Time Tools). If your python
> package is OS dependent (not pure python) then you don't want to include
> it with your plugin. My Density Analysis plugin can use the optional H3
> library (which I think might be worthwhile for QGIS to include as a part
> of its libraries), but it is machine dependent so I did not include it.
> It is not ideal to have users pip install the library, but you have to
> weigh the costs vs. the benefits of using some library.
> Good luck!
> On Thu, Jul 21, 2022 at 1:19 PM Gerald Kogler via QGIS-Developer
> <qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org>>
> wrote:
> I'm actually developing a QGIS plugin which depends on pysftp
> package to
> upload files to a server. For now I thought on asking users to install
> it manually, but it would be great to automatize the installation
> process.
> So the options I see would be:
> 1. Install external package using pip from inside the plugin.
> 2. Include and ship external package with the plugin.
> 3. Ask user to install it manually using pip install.
> Is there a recommended way to handle this situation?
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
