[QGIS-Developer] How to get the name for a QgsLayoutDesignerInterface object?
Raymond Nijssen r.nijssen at terglobo.nl
Fri Jul 29 04:22:48 PDT 2022
Wow, thank you so much, masterLayout() it is!
Raymond
On 29-07-2022 11:42, John Gitau wrote:
> Hi Raymond,
> For the window title, you can try designer.window().windowTitle().
> To get the QgsPrintLayout object, you can try designer.masterLayout()
> which has the .name() method.
> Cheers,
> John
> On Fri, 29 Jul 2022 at 12:04, Raymond Nijssen via QGIS-Developer
> <qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org>>
> wrote:
>     Hi developers,
>     I'm trying to get the name for a layout designer window, which is in a
>     python variable (designer) of type QgsLayoutDesignerInterface.
>     designer.layout() returns a QgsLayout object but that class does not
>     have a .name() function.
>     The QgsPrintLayout class does have a .name() function but I don't know
>     how to get a QgsPrintLayout object from my designer.
>     Anyone?
>     Kind regards,
>     Raymond
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> John Gitau
More information about the QGIS-Developer mailing list
