[QGIS-Developer] QGIS vs GEOS validity check
Jeff McKenna
jmckenna at gatewaygeomatics.com
Sat Jun 4 03:34:16 PDT 2022
Hi JF,
Regarding GEOS, please consider asking for more details through the
project's vibrant forum (subscribe at
https://lists.osgeo.org/mailman/listinfo/geos-devel ), I know there was
a big release made yesterday and some chatter (project home:
https://libgeos.org/ ) GEOS is one of those core libraries, who would
greatly appreciate your direct feedback.
PS. hello from the east coast
Thanks,
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2022-06-03 4:25 p.m., Bourdon, Jean-François (DIF) via QGIS-Developer
wrote:
> Intranet logo
> Hi Devs,
> I had a surprising issue with a specific vector layer and a clip
> operation. Validity check of the geometries seem to be done differently
> if native:clip is used inside a processing script or manually through
> the GUI as a vector layer containing a linestring with duplicate node
> like LINESTRING ((0 0, 1 0, 1 0)) won't cause an issue when the clip is
> done with the GUI but will halt if done inside a processing script (on
> QGIS 3.22.6).
> Also, if I run */qgis:checkvalidity/* with the *GEOS* method, no error
> is found, but if I run it with the *QGIS* method, it finds one error
> (/line 1 contains 2 duplicate nodes starting at vertex 2/). So here are
> my questions: what exactly is checked when using the GEOS method and
> what is checked using the QGIS method? Also, do all processing tools
> (qgis: and native: ones) use the same kind of check?
> I didn't find anywhere the details of what would be considered an error
> according to the "QGIS spec". Is it documented somewhere or do I need to
> look for hints inside the source code? As for the GEOS method, I only
> found some error examples in the PostGIS documentation and in a FME page
> (https://community.safe.com/s/article/invalid-ogc-geometry-examples
> <https://community.safe.com/s/article/invalid-ogc-geometry-examples>).
> Is there an official documentation of what geometries are invalid
> regarding GEOS?
> Thanks a lot for any pointer
> *Jean-François Bourdon, ing.f.*
> *Analyste en télédétection*
> *Direction des inventaires forestiers*
> *Ministère des Forêts, de la Faune et des Parcs*
> 5700, 4^e Avenue Ouest, local A-108
> Québec (Québec) G1H 6R1
> Téléphone : 418 627-8669, poste 704304
> *_jean-francois.bourdon at mffp.gouv.qc.ca_*
> *mffp.gouv.qc.ca* <http://www.mffp.gouv.qc.ca/accueil.jsp>
