[QGIS-Developer] Could anyone share the token setup for the backport bot?
Andrea Aime andrea.aime at geo-solutions.it
Wed Jun 8 00:07:48 PDT 2022
Think we figured that out, without a personal access token the workflows in
the generated PRs would not be run.
Cheers
Andrea
On Sun, Jun 5, 2022 at 4:54 PM Andrea Aime <andrea.aime at geo-solutions.it>
wrote:
> Hi all,
> I'm trying to set the backport bot up again in the GeoServer project.
> Seeing that you have it running, I copied over the set up, and indeed,
> it seems to be working fine for us as well (thanks!).
> One difference still outstanding is the github token being used,
> I've set up the common "secrets.GITHUB_TOKEN"
> <https://github.com/geoserver/geoserver/blob/main/.github/workflows/backport.yml#L18> but
> I see QGIS
> is using a customized one
> <https://github.com/qgis/QGIS/blob/master/.github/workflows/backport.yml#L18>
> I'm guessing a personal token associated with the
> https://github.com/qgis-bot user,
> probably set up in order to customize/restrict the set of actions
> that the action can perform...
> Could anyone share the configuration of said token (privately I presume)?
> Cheers
> Andrea
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220608/926aa435/attachment.htm>
More information about the QGIS-Developer mailing list
