[QGIS-Developer] gdal2xyz.bat not accepting -b any band number
Even Rouault
even.rouault at spatialys.com
Thu Jun 23 17:40:54 PDT 2022
Le 24/06/2022 à 02:29, Alexandre Neto via QGIS-Developer a écrit :
> I am testing the GDAL tools on QGIS 3.22.8 on Windows. When running
> gdal2xyz with a single band raster I am getting the following error:
> C:\Users\testing_user>gdal2xyz.bat -b 1
> C:/Users/testing_user/Desktop/gdal_commands_test/mdt_clipped.tif
> OUTPUT.csv
> usage: gdal2xyz.py [-h] [-skip] [-srcwin xoff yoff xsize ysize] [-b
> band [band ...]] [-allbands] [-csv] [-skipnodata]
> [-srcnodata [SRC_NODATA ...]] [-dstnodata
> [DST_NODATA ...]]
> src_dataset dst_dataset
> gdal2xyz.py: error: argument -b/-band/--band: invalid int value:
> 'C:/Users/testing_user/Desktop/gdal_commands_test/mdt_clipped.tif'
> If I remove the -b option it works.
> Windows Is now on GDAL 3.5.0. On my linux machine that still uses GDAL
> 3.0.4 it works fine.
> Bug report? In here or in GDAL?
to GDAL. It looks like the -b option is a bit too greedy in consuming
arguments. A workaround is to put the -b 1 option at the end of the
command line.
> Alexandre Neto
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
http://www.spatialys.com
