[QGIS-Developer] Fwd: Compile Master with Debian Bullseye
Richard Duivenvoorde rdmailings at duif.net
Wed Jun 29 04:36:06 PDT 2022
Hi Piet,
FYI: ccmake caches a lot apparently, so my way in such issues is often to remove the build directory, create it again, cd into it, and run "ccmake <with all your options> .." again (and then it often magically it finds stuff it earlier did not find...).
Keep on compiling :-)
Regards,
On 6/29/22 13:24, Piet via QGIS-Developer wrote:
> Dear Johannes,
> thank you very much for your kind answer!
> Meanwhile I solved this issue.
> I don't know why, but ccmake does not find the gdal library and I added the wrong library manually in the ccmake GUI.
> After the change to the correct library the compilation works fine!
> Kind regards
> Piet
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
