[QGIS-Developer] Merge tool always creating a new feature id instead of preserving the existing one
Andreas Neumann
a.neumann at carto.net
Tue Mar 1 01:24:52 PST 2022
Hi Alex,
Thank you for your reply.
In my case, the data resides in Postgis, not in Geopackage.
But if I understand you correctly, then Geopackage imposes it's limit on
QGIS in general, aka other providers as well - right?
Thanks,
Andreas
On 2022-03-01 10:16, Alexandre Neto wrote:
> I believe that comes from the geopackage fid limitations. For that
> reason, I never use the fid field as an actual id. That's my
> workaround.
> Alexandre Neto
> A terça, 1/03/2022, 08:44, Andreas Neumann <a.neumann at carto.net>
> escreveu:
>> Hi,
>> We have a problem with the merge tool.
>> We have a relatively complex data model with lots of relations. We
>> want to use the merge tool with this data.
>> The merge tool allows to carefully choose which attributes should end
>> up in the merged feature. This works fine, except for the feature ID.
>> QGIS stubbornly insists on having to create a new feature ID after the
>> merge - and is not reusing the feature ID of the original feature we
>> selected as the "master" feature in the merge tool.
>> This is a huge problem - because after the merge we loose all
>> relations, because the feature ID has changed.
>> Do you know any work around? Would we be able to fix this behaviour in
>> a future QGIS release?
>> Thanks for the discussion,
>> Andreas _______________________________________________
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220301/56fee2f5/attachment-0001.html>
