[QGIS-Developer] How to access QgisApp::instance() from a core class
Schmetzer, Tobias Tobias.Schmetzer at zae-bayern.de
Mon Mar 7 13:23:16 PST 2022
Hi Nyall,
> CORE classes must be completely non-gui, so that they work without issue on non-gui platforms like QGIS server (also for clients which have their own GUI, such as QFIeld/Input).
That sounds totally reasonable.
> Again, none of the core classes are allowed any GUI component, and the correct approach to handle this particular situation is to move that code from the provider level up to app level, specifically via the QgsDataItemGuiProvider class.
I had a look into it. If I understood it correctly the class provides a framework for functions to be registered and called by other functions placed in the gui.
But what to do when a progress dialog needs to be raised or an application state needs to be read? (see description below)
> So my question would be: why do you need to raise a user-facing message from QgsOgrProvider::extent?
- One idea was is to inform the user via a simple progress dialog in cases of very time-consuming extent calculations for large layers (I observed calc time ranges from 10 min to hours) of what's going on and that QGIS hasn't crashed yet. The design would practically allow this to be implemented in the provider and I also saw the use of QProgressDialog in other parts of the core components code. If that's also not how it is intended to be then I'd appreciate a quick hint of how it is intended to be.
- The second idea was to display an additional message dependant on the current QGIS instance's project state (whether it's loading/loaded/saving/closed) for which I had planned to introduce an enum QgisApp::ProjectState alongside with a private variable mProjectState and a public function QgisApp::getProjectState(). So would I make this accessible to the provider?
Best regards
Tobias
ZAE Bayern
Dipl.-Ing. Tobias Schmetzer
Systementwicklung | Systems Engineering
Bereich Energiespeicherung | Division Energy Storage
Walther-Meißner-Straße 6
85748 Garching
Tel.: +49 89 329442-65
Fax: +49 89 329442-12
Mobil | Cell: +49 151 56964756
tobias.schmetzer at zae-bayern.de
https://www.zae-bayern.de
ZAE Bayern
Bayerisches Zentrum für Angewandte Energieforschung e. V. | Bavarian Center for Applied Energy Research
Vorstand | Board: Dr. Andreas Hauer (Vorsitzender | Chairman), Dr. Hans-Peter Ebert
Sitz | Registered Office: Würzburg
Registergericht | Register Court: Amtsgericht Würzburg
Registernummer | Register Number: VR 1386
Hinweise zum Datenschutz unter https://www.zae-bayern.de/datenschutz
Von: Nyall Dawson <nyall.dawson at gmail.com>
Gesendet: Montag, 7. März 2022 00:03
An: Schmetzer, Tobias
Cc: qgis-developer at lists.osgeo.org
Betreff: Re: [QGIS-Developer] How to access QgisApp::instance() from a core class
On Sun, 6 Mar 2022 at 00:16, Schmetzer, Tobias via QGIS-Developer
<qgis-developer at lists.osgeo.org> wrote:
> Hello everyone,
> I would like to access QgisApp::instance() (src/app/qgisapp.cpp) from a provider like QgsOgrProvider::extent() (src/core/providers/ogr/qgsogrprovider.cpp.
You can't, by design.
Just to be super-blunt: There is 100% no way this will EVER change! ;)
> When looking for this information I found some inactivating preprocessor code block comments like this one (qgswfsdataitems.cpp):
> #if 0
>     // TODO: how to emit message from provider (which does not know about QgisApp)
>     QgisApp::instance()->messageBar()->pushMessage( tr( "Cannot copy style" ),
>         errorMsg,
>         Qgis::MessageLevel::Critical, messageTimeout() );
> #endif
This is very old code (hence why it's disabled). Again, none of the
Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220307/8c4e35b1/attachment-0001.html>
More information about the QGIS-Developer mailing list
