[QGIS-Developer] [Qgis-user] QGIS freezes for minutes when updated SpatiaLite SQL Layer
SIGéal
sigeal at sigeal.com
Tue Mar 22 02:54:51 PDT 2022
I created an issue :
https://github.com/qgis/QGIS/issues/47906
I can reproduce it with a dead simple query : select * from table
(returning ~ 800 rows).
And no problem with any query/database on QGIS 3.16.16 !
Thanks,
Christophe
Le 22/03/2022 à 10:41, Alexandre Neto a écrit :
> It probably also has something to do with the query you are using.
> Can you please create a ticket? Preferably with some sample data and
> project and explaining the steps to reproduce the problem.
> Thanks
> Alexandre Neto
> A terça, 22/03/2022, 09:24, SIGéal via Qgis-user
> <qgis-user at lists.osgeo.org> escreveu:
> Hi list,
> QGIS 3.22/3.24 freezes with hourglass for about 2 minutes when I
> click
> on close button of Update SQL Layer dialog, even if I didn't
> modify the
> query.
> If I click on Execute button, I get this error : "an error occurred
> while opening GPKG dbname=..."
> This happens with a big database file (600 Mb), only with with query
> returning hundreds of rows.
> I don't have any problem at all with old behaviour on QGIS 3.16.16
> : DB
> Manager opened when I click on Update SQL Layer.
> So this sounds clearly like a regression linked to the new "Update
> SQL
> Layer" dialog/behaviour.
> Thanks for any hint or work around,
> Christophe Damour
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220322/c67775d4/attachment-0001.html>
