[QGIS-Developer] Drag and drop form function QdateEdit Widget init
Richard Duivenvoorde
rdmailings at duif.net
Fri Mar 25 00:49:50 PDT 2022
On 3/25/22 08:33, PIERRE Sylvain via QGIS-Developer wrote:
> But this is not working with QDateEdit widget :
> today=date.today()
> control=dialog.findChild(QDateEdit,"date_insert")
> control.setDateTime(today)
> What is the right syntax to init the date widget ? It’s impossible to debug init script (or may be I’m missing something…)
Which module is 'date.today()' from, not Qt is it?
You probably have to use the QDatetime: https://doc.qt.io/qt-5/qdatetime.html#currentDateTime
>>> QDateTime.currentDateTime()
PyQt5.QtCore.QDateTime(2022, 3, 25, 8, 44, 19, 963)
And set THAT with the widget?
See: https://doc.qt.io/qt-5/qdatetimeedit.html#dateTime-prop
(it always a little hassle to juggle with date/time etc in Python/Qt)
Regards,
