[QGIS-Developer] Drag and drop form function QdateEdit Widget init
Andreas Neumann a.neumann at carto.net
Fri Mar 25 01:28:25 PDT 2022
Hi Pierre,
Not sure if you are aware that recent QGIS releases also have very good
"default" value support without having to use Python. You can simply set
default values with QGIS expressions. No need for Python code (unless
you do something really special).
You can even set date values dependent on other widgets without having
to use Python scripting - and do updates whenever something changes on
the record, without having to fall back to Python scripting.
Just wanted to make sure you are aware of this alternative mechanism.
There might still be good reasons for using Python scripting though -
but theses cases are now rarer.
Greetings,
Andreas
On 2022-03-25 09:17, Denis Rouzaud via QGIS-Developer wrote:
> QgsDateTimeEdit implements setDateTime, which is not virtual in
> QDateTimeEdit.
> It's probably that you have to find a QDateTimeEdit rather than the Qt
> native one.
> Not 100% sure this is the issue though, but it won't hurt.
> Le ven. 25 mars 2022 à 09:11, PIERRE Sylvain via QGIS-Developer
> <qgis-developer at lists.osgeo.org> a écrit :
>> Thanks for tip Richard, but I've tried with
>> today = QtCore.QDateTime.currentDateTime()
>> But it's not working
>> -----Message d'origine-----
>> De : Richard Duivenvoorde <rdmailings at duif.net>
>> Envoyé : vendredi 25 mars 2022 08:50
>> À : PIERRE Sylvain <sylvain.pierre at alsace.eu>;
>> Objet : Re: [QGIS-Developer] Drag and drop form function QdateEdit
>> Widget init
>> Soyez vigilant : ce courriel provient d'une organisation externe à la
>> CeA.
>> * Assurez-vous d'abord qu'il ne s'agit pas d'un email malveillant
>> avant de cliquer sur tout lien ou pièce jointe.
>> On 3/25/22 08:33, PIERRE Sylvain via QGIS-Developer wrote:
>>> But this is not working with QDateEdit widget :
>>> today=date.today()
>>> control=dialog.findChild(QDateEdit,"date_insert")
>>> control.setDateTime(today)
>>> What is the right syntax to init the date widget ? It's impossible to
>>> debug init script (or may be I'm missing something...)
>> Hi,
>> Which module is 'date.today()' from, not Qt is it?
>> You probably have to use the QDatetime:
>> https://doc.qt.io/qt-5/qdatetime.html#currentDateTime
>> PyQt5.QtCore.QDateTime(2022, 3, 25, 8, 44, 19, 963)
>> And set THAT with the widget?
>> See: https://doc.qt.io/qt-5/qdatetimeedit.html#dateTime-prop
>> (it always a little hassle to juggle with date/time etc in Python/Qt)
>> Regards,
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220325/24b60ff3/attachment-0001.html>
More information about the QGIS-Developer mailing list
