[QGIS-Developer] Unexpected results from GPKG table query using executeSql()
Raymond Nijssen
r.nijssen at terglobo.nl
Thu Mar 31 23:28:28 PDT 2022
For a workaround I found that selecting this way:
SELECT
edit_id + 0 AS edit_id,
timestamp,
name
FROM
The +0 seem to makes QGIS (or GDAL?) unaware of edit_id being the PK
field and it does return it. Works both in 3.10 and 3.25.
Raymond
On 31-03-2022 18:15, Alessandro Pasotti wrote:
> Hi Raymond,
> your code looks good.
> Can you provide a test file?
> There are some test in core here:
> https://github.com/qgis/QGIS/blob/master/tests/src/python/test_qgsproviderconnection_ogr_gpkg.py
> <https://github.com/qgis/QGIS/blob/master/tests/src/python/test_qgsproviderconnection_ogr_gpkg.py>
> On Thu, Mar 31, 2022 at 6:09 PM Raymond Nijssen via QGIS-Developer
> <qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org>>
> wrote:
> Hi devs,
> I'm working on a plugin that connects to a custom table (without
> geometry) in a GPKG. When I'm sending queries to it, I keep on getting
> unexpected results. Somehow the id field is missing, sometimes it
> appears twice (!). And this seems to be different between QGIS 3.10 and
> 3.25. (I think it changed since 3.22).
> Here is a piece of my code:
> fn = '/path/to/test.gpkg'
> md = QgsProviderRegistry.instance().providerMetadata('ogr')
> conn = md.createConnection(fn, {})
> q = 'select * from test_table;'
> qr = conn.executeSql(q)
> print(qr) # No id field in result
> Before diving into the QGIS code I'd like to check if this is the
> way to
> go. Or should i use another way to query that GPKG (SQLite) db?
> Kind regards,
> Raymond
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> QCooperative: www.qcooperative.net <https://www.qcooperative.net>
> ItOpen: www.itopen.it <http://www.itopen.it>
