[QGIS-Developer] QGIS compile python issue Debian Testing/Bookworm?
Richard Duivenvoorde
rdmailings at duif.net
Thu May 5 11:03:51 PDT 2022
Sorry for the noise, I just messed up my python(s) on my system...
All fine here :-)
Regards,
Richard
On 5/5/22 19:16, Richard Duivenvoorde via QGIS-Developer wrote:
> Hi Configuring qgis, I get:
> Pedantic compiler settings enabled
> Debug output enabled
> Found GSL: -L/usr/lib/x86_64-linux-gnu -lgsl -lgslcblas -lm
> -- Found Python executable: /usr/bin/python3.9 (version 3.9.12)
> -- Python library: /usr/lib/x86_64-linux-gnu/libpython3.9.so
> -- Python site-packages: /usr/lib/python3/dist-packages
> Traceback (most recent call last):
> File "/home/richard/git/qgis/cmake/FindSIP.py", line 34, in <module>
> import sipbuild
> File "/usr/lib/python3/dist-packages/sipbuild/__init__.py", line 25, in <module>
> from .abstract_builder import AbstractBuilder
> File "/usr/lib/python3/dist-packages/sipbuild/abstract_builder.py", line 26, in <module>
> from .configurable import Configurable
> File "/usr/lib/python3/dist-packages/sipbuild/configurable.py", line 24, in <module>
> from packaging.markers import Marker
> ModuleNotFoundError: No module named 'packaging'
> During handling of the above exception, another exception occurred:
> File "/home/richard/git/qgis/cmake/FindSIP.py", line 44, in <module>
> import sipconfig
> ModuleNotFoundError: No module named 'sipconfig'
> CMake Error at cmake/FindSIP.cmake:58 (MESSAGE):
> Could not find SIP
> Call Stack (most recent call first):
> CMakeLists.txt:958 (find_package)
> Configuring incomplete, errors occurred!
> See also "/home/richard/git/qgis/build/CMakeFiles/CMakeOutput.log".
> See also "/home/richard/git/qgis/build/CMakeFiles/CMakeError.log".
> I know there is also python 3.10 coming in...
> I think I have all sip related stuff installed:
> $ apt search sip | grep python
> WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
> kamailio-python3-modules/testing,testing 5.5.4-1+b2 amd64
> app_python3 module for the Kamailio SIP server
> python-sip-doc/testing,testing 4.19.25+dfsg-3 all
> python3-aioice/testing,testing 0.7.7-1 all
> python3-pyqt5.sip/testing,testing,now 12.10.1-1 amd64 [installed,automatic]
> python3-pyqt6.sip/testing,testing,now 13.3.1-1 amd64 [installed]
> python3-pyqtbuild/testing,testing,now 1.12.2+dfsg-1 all [installed]
> python3-python-qt-binding/testing,testing 0.4.4-1 all
> python3-sip/testing,testing,now 4.19.25+dfsg-3+b1 amd64 [installed]
> python3-sip-dev/testing,testing,now 4.19.25+dfsg-3+b1 amd64 [installed]
> python3-sipbuild/testing,testing,now 6.5.1+dfsg-1 amd64 [installed]
> python3-siphashc/testing,testing 2.1-0.1 amd64
> python c-module for siphash, based on floodberry's version
> python3-socks/testing,testing 1.7.1+dfsg-1 all
> python3-socksipychain/testing,testing 2.1.2-1 all
> python3-stdnum/testing,testing 1.17-1 all
> python3-transip/testing,testing 2.0.0-3 all
> Others having problems on bookworm?
> Any pointers?
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
