[QGIS-Developer] QGIS Modelbuilder, Persisting Filepaths+Filenames
pathmapper pathmapper at posteo.de
Fri May 6 04:12:33 PDT 2022
if you run your model from the model builder (green "play" button) and
not from the processing toolbox, your settings will be preserved (if you
open the .model3 file with a text editor, watch out for
'designerParameterValues').
Cheers,
Björn
On 06.05.2022 12:29, Johannes Kröger  via QGIS-Developer wrote:
> Hi Elliot,
> persist in what kind of context? Maybe setting project variables
> (there is a tool for that) would be sufficient?
> Cheers, Hannes
> Am 05.05.22 um 22:28 schrieb Elliott, Robert via QGIS-Developer:
>> Just realized I can only do what I want to do in QGIS, ArcGIS
>> won’t do it. Trying to load 25 KML files, merge and export as a
>> single shapefile. I can do everything I need to do in QGIS but one
>> question, when you create a model in modelbuilder is there a way to
>> persist the filepaths and filenames after initially running the
>> model so that I don’t have keep selecting the files, alternatively
>> can I load the filepath+filenames from a config (text) file?
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> [1]
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> [1]
> Johannes Kröger / GIS-Entwickler/-Berater
> Schon gewusst?
> In unserem Blog geben wir Tipps & Tricks zu Open-Source-GIS-Software
> und berichten aus unserem Experten-Alltag:
> https://wheregroup.com/blog/ [2]
> WhereGroup GmbH
> Grevenweg 89
> 20537 Hamburg
> Germany
> Tel: +49 (0)228 / 90 90 38 - 36
> Fax: +49 (0)228 / 90 90 38 - 11
> johannes.kroeger at wheregroup.com
> www.wheregroup.com [3]
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Links:
> [1] https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [2] https://wheregroup.com/blog/
> [3] http://www.wheregroup.com
More information about the QGIS-Developer mailing list
