[QGIS-Developer] Github required checks blocking pull requests
Nyall Dawson nyall.dawson at gmail.com
Thu May 12 14:23:29 PDT 2022
On Fri, 13 May 2022 at 06:00, Martin Dobias via QGIS-Developer
<qgis-developer at lists.osgeo.org> wrote:
> Hi all
> It seems like a PR https://github.com/qgis/QGIS/pull/47887 that has been merged recently  is now causing trouble in CI, making checks of new pull requests to hang indefinitely.
> From what I understand, the PR updated fedora version from 34 to 36, yet in Github configuration of required checks is that builds with version 34 are still required, but now they are never triggered. It looks like QGIS repo settings need to be adjusted to reflect that. Could somebody with admin rights to the QGIS repo fix it please? :-)
Fixed now.
> It's just a bit unfortunate that this happened shortly before the feature freeze, when there's a lot of action going on and blocking things. Maybe even worth extending FF for a couple of days to make sure that all PRs that were ready to go actually get merged?
I've tagged all the open feature PRs with "freeze exempt" for now (and
will do so for any opened today too). I'll remove that tag if they
don't get merge-ready within ~ 1 week.
Nyall
> Regards
> Martin
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
