[QGIS-Developer] Add algorithm to an existing provider?
Raymond Nijssen
r.nijssen at terglobo.nl
Fri May 13 02:48:06 PDT 2022
Hi Benjamin, thanks for your reply.
I'm not sure how the provider should "save a reference on my algorithm".
What do you mean?
Some things I tried:
self.provider = TestProvider()
QgsApplication.processingRegistry().addProvider(self.provider)
alg2 = TestAlgorithm2()
alg2.setProvider(self.provider) # Maybe this is "setting a reference??
self.provider.addAlgorithm(alg2)
# Now the provider shows the extra algorithms (but not in the GUI)
print(self.provider.algorithms())
# Attempts to get it in the GUI:
self.provider.refreshAlgorithms()
self.provider.loadAlgorithms()
self.provider.load()
Still no luck!
Regards,
Raymond
On 13-05-2022 09:07, Benjamin Jakimow wrote:
> Hi Raymond,
> you need to ensure that your provider saves a python reference on your
> TestAlgorithm2() (which you probably already do).
> After its set of algorithms has changed (i.e. refresh, addAlgorithm(s)
> etc.) it needs to emit the algorithmsLoaded signal.
> Greetings,
> Benjamin
> On 2022-05-13 08:15, Raymond Nijssen via QGIS-Developer wrote:
>> Is there a way to add a processing algorithm to an existing provider
>> using pyqgis?
>> I have 2 plugins and don't know if they are both installed (or which
>> one will load first). The both contain processing algorithms and I
>> want those to end up in the same group.
>> Documentation is a bit brief on this:
>> QgsProcessingProvider
>> Examples show to put the addAlgorithm() function(s) in the
>> loadAlgorithms() function. Then calling
>> QgsApplication.processingRegistry().addProvider(provider)
>> adds the group (=provider?) and the algorithms are in it.
>> What I want to do is finding the provider if it exists already:
>> self.provider = QgsApplication.processingRegistry().providerById('test')
>> if self.provider is None:
>> self.provider = RayProvider()
>> and then:
>> self.provider.addAlgorithm(TestAlgorithm2())
>> This doesn't work, neither when doing:
>> provider.load()
>> I'm currently trial-and-errorring my way through this, but I hope
>> someone has a hint. Even someone pointing at 2 plugins working like
>> this would be very welcome!
>> Kind regards,
>> Raymond
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
