[QGIS-Developer] Broken coordinate/distance/area calculation tests
DelazJ
delazj at gmail.com
Wed Nov 2 02:31:16 PDT 2022
For reference, I finally went with what the test was expecting
https://github.com/qgis/QGIS-Documentation/commit/16536686a93ce126d97926539b31aa4a16402f02
Harrissou
Le lun. 31 oct. 2022 à 00:11, Delaz J <delazj at gmail.com> a écrit :
> Hi,
> Thanks Nyall. No, no changes I'm aware of:
> https://github.com/qgis/QGIS-Documentation/commits/master
> master itself is(was?) green. It is the latest PR
> <https://github.com/qgis/QGIS-Documentation/pull/7849> that fails, and
> given that it touches nothing related to tests, I suspect the culprit is
> somewhere in the qgis docker image we pull.
> Regards,
> Harrissou
> Le 30/10/2022 à 23:20, Nyall Dawson a écrit :
> On Fri, 28 Oct 2022 at 16:10, Harrissou s. via QGIS-Developer<qgis-developer at lists.osgeo.org> <qgis-developer at lists.osgeo.org> wrote:
> Hi,
> I am wondering if the method for area/distance calculation has changed again in master or if the issue is in some transformation accuracy changes.
> In QGIS docs, we are getting failing tests for calculation we did not touch the underlying data for years.
> See starting from https://github.com/qgis/QGIS-Documentation/actions/runs/3339628288/jobs/5530428647#step:6:703
> Was there any corresponding updates to the test infrastructure? This
> looks to me like a proj library update has been installed.
> Nyall
> Regards,
> Harrissou
> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221102/c2611ebf/attachment.htm>
