[QGIS-Developer] segmentation fault in standalone script using PyQGIS
Mélanie Dol
Melanie.Dol at sat-ocean.com
Thu Nov 3 10:03:26 PDT 2022
Hi Jacky,
Thank you, it's working.
Best regards,
Mélanie
On 11/2/22 4:50 PM, Jacky Volpes via QGIS-Developer wrote:
> Hi,
> See answers below.
> Best regards.
> Jacky
> Le 31/10/2022 à 17:26, Mélanie Dol via QGIS-Developer a écrit :
>> Hi Jacky,
>> Thank you so much, the segmentation fault has disappeared.
>> However, my styles don't work. I guess my script can't access to my
>> symbols pre-configured. Is there a path to add or anything else ?
> You have to specify the QGIS profile directory path in which the
> symbols are saved.
> For example :
> qgs = QgsApplication([], False,
> '/home/jacky/.local/share/QGIS/QGIS3/profiles/default')
>> Another question, how to force a label placement mode to "horizontal" ?
> the line "layer_settings.LabelPlacement = 4" should be changed to
> "layer_settings.placement = 4"
> you can also use the enum : "layer_settings.LabelPlacement =
> QgsPalLayerSettings.Placement.Horizontal"
>> Many thanks and regards,
>> Mélanie
>> On 10/31/22 12:14 PM, Jacky Volpes via QGIS-Developer wrote:
>>> Hi Mélanie,
>>> Thanks for the script, I was able to reproduce the segmentation
>>> fault with a dummy gpkg I made.
>>> After some investigations, it seems that the symbol named
>>> "style_layer" used in
>>> 1. the addSymbol() method for the first layer
>>> 2. & 3. the QgsRendererCategory() constructor for the second and
>>> third layer
>>> is None (nullptr -> hence the segfault).
>>> If I add the following
>>> if style_layer is None:
>>> style_layer =
>>> QgsSymbol.defaultSymbol(Layer_Pressure_Center.geometryType())
>>> just before using style_layer as a safe check (for each layer of
>>> course) everything works fine.
>>> Maybe it's simply because I don't have these symbols pre-configured,
>>> but it's worth the check on your side.
>>> Also, I encapsulated the code like this, which prevents another
>>> segfault to occur due to local/global scope stuff I think:
>>> all imports
>>> def main():
>>> the main code
>>> if__name__ == '__main__':
>>> set prefix path
>>> create qgs application
>>> append plugins path to sys.path and import processing stuff
>>> main()
>>> qgs.exitQgis()
>>> Regards,
>>> Jacky
>>> Le 28/10/2022 à 17:10, Mélanie Dol via QGIS-Developer a écrit :
>>>> Hi Jacky,
>>>> Yes of course. Please find attached my script.
>>>> Regards,
>>>> Mélanie
>>>> On 10/28/22 4:55 PM, Jacky Volpes via QGIS-Developer wrote:
>>>>> Hi Mélanie,
>>>>> Have you initialized your standalone script as shown in
>>>>> https://docs.qgis.org/3.22/en/docs/pyqgis_developer_cookbook/intro.html#using-pyqgis-in-standalone-scripts
>>>>> Best regards,
>>>>> Jacky
>>>>> Le 28/10/2022 à 16:40, Mélanie Dol via QGIS-Developer a écrit :
>>>>>> Hi Andrea,
>>>>>> Thank you. I've updated with QGIS 3.26 Buenos Aires. The warning
>>>>>> message have disappeared. Unfortunately, the script still
>>>>>> generates a segmentation fault.
>>>>>> Best regards,
>>>>>> Mélanie Dol
>>>>>> On 10/28/22 11:47 AM, Andrea Giudiceandrea via QGIS-Developer wrote:
>>>>>>> Il 27/10/2022 16:34, Mélanie Dol via QGIS-Developer ha scritto:
>>>>>>>> /usr/share/qgis/python/plugins/processing/algs/grass7/Grass7Utils.py:191:
>>>>>>>> SyntaxWarning: "is" with a literal. Did you mean "=="?
>>>>>>>> if path is '':
>>>>>>> Hi Mélanie,
>>>>>>> while I don't know why that script generates a segmentation
>>>>>>> fault, It seems you are using QGIS 3.10 which is a three years
>>>>>>> old version. The QGIS repository for Ubuntu 20.04 currently
>>>>>>> offers the latest available QGIS LTR 3.22.12.
>>>>>>> Best regards.
>>>>>>> _______________________________________________
>>>>>>> QGIS-Developer mailing list
>>>>>>> QGIS-Developer at lists.osgeo.org
>>>>>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> Jacky Volpes
>>>>> Ingénieur SIG - Oslandia
>>> Jacky Volpes
> Jacky Volpes
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221103/bdb9309d/attachment-0001.htm>
