[QGIS-Developer] msi package error
Paul N
surveykshak at gmail.com
Thu Nov 10 07:55:53 PST 2022
I want to create a .msi setup for my build and my compilation was
successful. I am facing a problem while creating a .msi file.
My OSGeo4W structure is
C:\OSGeo4W
Source Code : C:\OSGeo4W\QGIS_3_22
Script folder downloaded from https://github.com/jef-n/OSGeo4W
C:\OSGeo4W\QGIS_3_22\ms-windows\scripts
C:\OSGeo4W\QGIS_3_22\ms-windows\src
C:\OSGeo4W\QGIS_3_22\ms-windows\doc
After running createmsi.pl following folders created
C:\OSGeo4W\QGIS_3_22\ms-windows\scripts\tmp
C:\OSGeo4W\QGIS_3_22\ms-windows\scripts\tmp\packages
C:\OSGeo4W\QGIS_3_22\ms-windows\scripts\tmp\unpacked
then I have moved Installer-Files folder to tmp
C:\OSGeo4W\QGIS_3_22\ms-windows\scripts\tmp\Installer-Files
Now after running createmsi.pl
It give output as
PS C:\OSGeo4W\QGIS_3_22\ms-windows\scripts> perl .\createmsi.pl
2022-11-10 21:09:08 URL:
http://download.osgeo.org/osgeo4w/v2/x86_64/setup.ini [289659/289659] ->
"setup.ini" [1]
FIND: Parameter format not correct
installer.wxs
QGISInstallDirDlg.wxs
QGISUI_InstallDir.wxs
and creates three files
C:\OSGeo4W\QGIS_3_22\ms-windows\scripts\tmp\packages\QGIS-OSGeo4W-3.22.12-1.msi
size 488KB
C:\OSGeo4W\QGIS_3_22\ms-windows\scripts\tmp\packages\QGIS-OSGeo4W-3.22.12-1.sha256sum
size 1KB
C:\OSGeo4W\QGIS_3_22\ms-windows\scripts\tmp\packages\QGIS-OSGeo4W-3.22.12-1.wixpdb
size 503KB
Where "FIND: Parameter format not correct" ?
Please help Jurgen Fischer
Thanks
Paul N
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221110/697cce10/attachment.htm>
