[QGIS-Developer] Project loader profiler Postgres Layers
Julien Cabieces
julien.cabieces at oslandia.com
Wed Nov 16 00:55:13 PST 2022
Hi Remi,
Which profiler are you talking about ?
Did you try to use the the new Debugging/Developement tool ? It's new
since QGIS 3.26 and will give you the list of requests and the time
spent for each one when loading a project/layer or opening the attribute
table.
Regards,
Julien
> Hi,
> I’m profiling large project loading, I think this mailing list doesn’t support images, so I won’t post any.
> I’m posting in the dev mailing list since I dived into the code and found nothing 😅.
> When you load a Postgres layer, the profiler list 3 steps:
> * Read layer metadata
> * Read layer fields
> * Create postgres provider
> This “Create postgres provider” takes a while on some table (I have ‘use estimated table metadata’. In the connection.)
> I `git greped` the code and cannot found where this “span” happened and what requests are made to the server, I could look out on the server logs, sadly I don’t have access to it :-/
> I already saw some weird behavior on 3.28 where QGIS launch ~25 SQL requests when loading a new layer, but I’d like to have solid fact before posting an issue on github.
> Thx, Rémi.
