[QGIS-Developer] Project loader profiler Postgres Layers
Rémi Desgrange remi.desgrange at ielo.net
Wed Nov 16 13:57:35 PST 2022
@Julien sorry for not being clear, I used the Debugging/Developement tool 😊
@René-Luc Thanks I’ll look into it.
From: QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> on behalf of René-Luc Dhont via QGIS-Developer <qgis-developer at lists.osgeo.org>
Date: Wednesday, 16 November 2022 at 10:06
To: qgis-developer at lists.osgeo.org <qgis-developer at lists.osgeo.org>
Subject: Re: [QGIS-Developer] Project loader profiler Postgres Layers
Hi Rémi,
During the provider creation, a lot of SQL requests are made to check a lot of thing even if the use estimated metadata is checked :
* Fields list
* geometry type
* primary key
* extent
* capabilities (read, insert, update, delete)
You can take a look at these PRs to have an idea on all the SQL request made at the creation :
* https://github.com/qgis/QGIS/pull/49440
* https://github.com/qgis/QGIS/pull/50186
Regards,
René-Luc
Le 16/11/2022 à 09:55, Julien Cabieces via QGIS-Developer a écrit :
Hi Remi,
Which profiler are you talking about ?
Did you try to use the the new Debugging/Developement tool ? It's new
since QGIS 3.26 and will give you the list of requests and the time
spent for each one when loading a project/layer or opening the attribute
table.
Regards,
Julien
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221116/967d3d14/attachment.htm>
More information about the QGIS-Developer mailing list
