[QGIS-Developer] Long filename/filepath causing git issues
Alexis R.L.
alroyliz0 at gmail.com
Tue Nov 29 13:13:29 PST 2022
Greetings,
It seems there is a local solution by changing a git settings or two ( see
https://stackoverflow.com/questions/22575662/filename-too-long-in-git-for-windows
Given that there's a workaround, I'm more hesitant about proposing a PR as
it can be fixed locally (though might require admin right).
Cheers,
Alex
Le ven. 25 nov. 2022 à 14:23, Even Rouault <even.rouault at spatialys.com> a
écrit :
> > Would it be too crazy to shrink down some offending name to prevent
> > error when switching to more recent branches? I can submit a PR if
> needed.
> Seems like a good idea. You'll likely have to change references to that
> file in the test suite.
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221129/894dbec1/attachment.htm>
