[QGIS-Developer] QGIS Upgrade/Update Inquiry
John Bingco
john.bingco at elevate.com.au
Wed Oct 5 17:14:36 PDT 2022
Thanks for your response Alexandre. 😊
Regards,
John
Sent: Wednesday, 5 October 2022 11:17 PM
To: John Bingco <john.bingco at elevate.com.au>
Cc: qgis-dev <qgis-developer at lists.osgeo.org>
Subject: Re: [QGIS-Developer] QGIS Upgrade/Update Inquiry
Hi, It's important to know what is the current version you are using and what is the version you want to update to. I would suggest using 3.22 LTR. Nevertheless, both 3.22 LTR and 3.26 versions should
External (senhor.neto at gmail.com<mailto:senhor.neto at gmail.com>)
Report This Email<https://protection.inkyphishfence.com/report?id=ZWxldmF0ZXRlY2hub2xvZ3kvam9obi5iaW5nY29AZWxldmF0ZS5jb20uYXUvNzZlNGIxYjQxODg4MmY2ZWUxNzQxYTIzZjJiNTIyOGQvMTY2NDk3NTg2Ny45MQ==#key=ef4f9841b681443d6e6a86963effe5c1> FAQ<https://www.elevate.com.au/banner-faq/> Protection by ELEVATE<https://www.elevate.com.au/>
Nevertheless, both 3.22 LTR and 3.26 versions should be retro compatible with most 3.x versions.
Best regards
Alexandre Neto
User support
www.qcooperative.net<https://shared.outlook.inky.com/link?domain=www.qcooperative.net&t=h.eJxFjUEOgyAUBa9iWDcQKAK68iqAX7FFvqWoaZrevSFp0u2bl5k32XMkfUNCKVvP2Hme9OERN8i2LAfQBIVcGnKvH4hw2AIFfEgYcX6xG4ZE3ZJmj8OPUo8rtTvTCqTjTnJjjJgUANeSW3GdhGuFMCPjSslOt0Zp2vHagNp4QgqYaxaHebVLrL5Kx0r_y-cLUjQ6qQ.MEYCIQCILi6LZhpsrz7xvnrYqTRnJnjghYl8KA9kOlaKV6HvfQIhAPBvEeWhxmLXPjfPf-uLJ7xbv738D9pSThEWJyqnJyQl>
A quarta, 5/10/2022, 06:22, John Bingco via QGIS-Developer <qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org>> escreveu:
Hi Team,
I work for an IT service provider in Australia and we are working with a client that uses QGIS.
The client is requesting for their QGIS to be updated/upgraded to the latest version. Just wanted to check if there is anything we need to take note when doing the update/upgrade. User is worried about compatibility issues.
If there is none, are we good to just directly install the latest version on server for all users to have updated version of the software?
Appreciate your response on this. 😊
Regards,
John
[cid:image650414.gif at 1C4D4FA4.7AD52164]
John Bingco
TECHNICIAN
ELEVATE TECHNOLOGY
Mackay, Brisbane, & Newcastle
P:
1300 463 538
W:
www.elevate.com.au<https://www.elevate.com.au/>
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org<mailto:QGIS-Developer at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer<https://shared.outlook.inky.com/link?domain=lists.osgeo.org&t=h.eJxFjkEOwiAURK9iWCsEbIF21avQ9hdQyq9Amxjj3Q3GxO28zLx5kT0F0p-IK2XLPWPB55IpZgtIMVm2Gh9WE7-5jwuyh_X5MsMBATdI5Hwi99qHAIcpUGByEQPaJ7uhi3T00U44_CidcKVmZ0pCM_Kx4VprsUgArhpuxHURYyuEnhmXsulUq6WiHa8OqI4M0WGiEQoOth6re5XOlf6T9wei1UVt.MEQCIG6AOsXFgdsbShR6TeX69RfxTK4WNb2BnG8NKhtPCFwcAiAttFg4f2Rmp-OrAM0w-zh-lkR57lYtTfEO-PfDYh4eBw>
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer<https://shared.outlook.inky.com/link?domain=lists.osgeo.org&t=h.eJxFjkEOwiAURK9iWCsEbIF21avQ9hdQyq9Amxjj3Q3GxO28zLx5kT0F0p-IK2XLPWPB55IpZgtIMVm2Gh9WE7-5jwuyh_X5MsMBATdI5Hwi99qHAIcpUGByEQPaJ7uhi3T00U44_CidcKVmZ0pCM_Kx4VprsUgArhpuxHURYyuEnhmXsulUq6WiHa8OqI4M0WGiEQoOth6re5XOlf6T9wei1UVt.MEQCIG6AOsXFgdsbShR6TeX69RfxTK4WNb2BnG8NKhtPCFwcAiAttFg4f2Rmp-OrAM0w-zh-lkR57lYtTfEO-PfDYh4eBw>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221006/b3a690de/attachment-0001.htm>
