[QGIS-Developer] PyQt db_manager(?) compile error
Richard Duivenvoorde
rdmailings at duif.net
Mon Jan 30 11:34:41 PST 2023
Ok, so the crux was:
sudo apt install libqt5multimedia5 python3-pyqt5.qtmultimedia
I did install the first one, but the other not (yet)
Thanks Even R !
Richard
On 1/30/23 13:04, matteo via QGIS-Developer wrote:
> Hi Richard,
> same here. On Debian with a new folder and a fresh compilation. Did you solved?
> make[2]: *** [python/plugins/db_manager/CMakeFiles/zzz-db_manager-15-depend.dir/build.make:90: python/plugins/db_manager/ui_DlgCancelTaskQuery.py] Error 1
> make[2]: *** Deleting file 'python/plugins/db_manager/ui_DlgCancelTaskQuery.py'
> make[2]: *** [python/plugins/db_manager/CMakeFiles/zzz-db_manager-15-depend.dir/build.make:98: python/plugins/db_manager/ui_DlgCreateIndex.py] Error 1
> make[2]: *** Deleting file 'python/plugins/db_manager/ui_DlgCreateIndex.py'
> make[2]: *** [python/plugins/db_manager/CMakeFiles/zzz-db_manager-15-depend.dir/build.make:102: python/plugins/db_manager/ui_DlgCreateTable.py] Error 1
> make[2]: *** Deleting file 'python/plugins/db_manager/ui_DlgCreateTable.py'
> An unexpected error occurred.
> Check that you are using the latest version of PyQt5 and send an error report to
> support at riverbankcomputing.com, including the following information:
> * your version of PyQt (5.15.8)
> * the UI file that caused this error
> * the debug output of pyuic5 (use the -d flag when calling pyuic5)
> make[2]: *** [python/plugins/db_manager/CMakeFiles/zzz-db_manager-15-depend.dir/build.make:94: python/plugins/db_manager/ui_DlgCreateConstraint.py] Error 1
> make[2]: *** Deleting file 'python/plugins/db_manager/ui_DlgCreateConstraint.py'
> make[1]: *** [CMakeFiles/Makefile2:6344: python/plugins/db_manager/CMakeFiles/zzz-db_manager-15-depend.dir/all] Error 2
> Cheers
> Matteo
> On 1/27/23 13:23, Richard Duivenvoorde via QGIS-Developer wrote:
>> Hi,
>> Compiling master on Debian Testing today, I first was presented with a new dependency Qt5Multimedia (hopefully we can soon use QGIS as a Spotify client ;-) ), which was installable.
>> But then my (fresh) build stalls at:
>> [9773/9812] Generating ui_DlgAddGeometryColumn.py
>> FAILED: python/plugins/db_manager/ui_DlgAddGeometryColumn.py /home/richard/git/qgis/build/python/plugins/db_manager/ui_DlgAddGeometryColumn.py
>> cd /home/richard/git/qgis/build/python/plugins/db_manager && /home/richard/git/qgis/scripts/pyuic_wrapper.sh /usr/bin/pyuic5 /home/richard/git/qgis/build/output/lib /home/richard/git/qgis/build/output/python /usr/bin/python3 /home/richard/git/qgis/python/plugins/db_manager/ui/DlgAddGeometryColumn.ui -o /home/richard/git/qgis/build/python/plugins/db_manager/ui_DlgAddGeometryColumn.py
>> * your version of PyQt (5.15.7)
>> Others have that issue?
>> Running pyuic -d on one of the errors seems fine (see below).
>> Regards,
>> /usr/bin/pyuic5 -d /home/richard/git/qgis/python/plugins/db_manager/ui/DlgExportVector.ui
>> PyQt5.uic.uiparser: uiname is DbManagerDlgExportVector
>> PyQt5.uic.uiparser: toplevel widget is QDialog
>> PyQt5.uic.properties: setting property geometry
>> PyQt5.uic.properties: setting property windowTitle
>> PyQt5.uic.uiparser: push QDialog DbManagerDlgExportVector
>> PyQt5.uic.uiparser: push QGridLayout gridLayout_2
>> PyQt5.uic.properties: setting property text
>> PyQt5.uic.uiparser: push QLineEdit editOutputFile
>> PyQt5.uic.uiparser: pop widget QLineEdit editOutputFile
>> PyQt5.uic.uiparser: new topwidget DbManagerDlgExportVector
>> PyQt5.uic.properties: setting property orientation
>> PyQt5.uic.properties: setting property standardButtons
>> PyQt5.uic.uiparser: push QDialogButtonBox buttonBox
>> PyQt5.uic.uiparser: pop widget QDialogButtonBox buttonBox
>> PyQt5.uic.uiparser: push QComboBox cboFileFormat
>> PyQt5.uic.uiparser: pop widget QComboBox cboFileFormat
>> PyQt5.uic.properties: setting property sizePolicy
>> PyQt5.uic.uiparser: push QLabel label_5
>> PyQt5.uic.uiparser: pop widget QLabel label_5
>> PyQt5.uic.properties: setting property title
>> PyQt5.uic.uiparser: push QGroupBox groupBox_2
>> PyQt5.uic.uiparser: push QCheckBox chkDropTable
>> PyQt5.uic.uiparser: pop widget QCheckBox chkDropTable
>> PyQt5.uic.uiparser: new topwidget self.groupBox_2
>> PyQt5.uic.uiparser: push QHBoxLayout horizontalLayout
>> PyQt5.uic.uiparser: push QCheckBox chkSourceSrid
>> PyQt5.uic.uiparser: pop widget QCheckBox chkSourceSrid
>> PyQt5.uic.properties: setting property enabled
>> PyQt5.uic.uiparser: push QLineEdit editSourceSrid
>> PyQt5.uic.uiparser: pop widget QLineEdit editSourceSrid
>> PyQt5.uic.uiparser: push QCheckBox chkTargetSrid
>> PyQt5.uic.uiparser: pop widget QCheckBox chkTargetSrid
>> PyQt5.uic.uiparser: push QLineEdit editTargetSrid
>> PyQt5.uic.uiparser: pop widget QLineEdit editTargetSrid
>> PyQt5.uic.uiparser: pop layout QHBoxLayout horizontalLayout
>> PyQt5.uic.properties: setting property toolTip
>> PyQt5.uic.uiparser: push QCheckBox chkEncoding
>> PyQt5.uic.uiparser: pop widget QCheckBox chkEncoding
>> PyQt5.uic.properties: setting property editable
>> PyQt5.uic.properties: setting property insertPolicy
>> PyQt5.uic.uiparser: push QComboBox cboEncoding
>> PyQt5.uic.uiparser: pop widget QComboBox cboEncoding
>> PyQt5.uic.uiparser: pop layout QGridLayout gridLayout
>> PyQt5.uic.uiparser: pop widget QGroupBox groupBox_2
>> PyQt5.uic.uiparser: push QToolButton btnChooseOutputFile
>> PyQt5.uic.uiparser: pop widget QToolButton btnChooseOutputFile
>> PyQt5.uic.uiparser: pop layout QGridLayout gridLayout_2
>> PyQt5.uic.uiparser: pop widget QDialog DbManagerDlgExportVector
>> PyQt5.uic.uiparser: new topwidget None
>> # -*- coding: utf-8 -*-
>> # Form implementation generated from reading ui file '/home/richard/git/qgis/python/plugins/db_manager/ui/DlgExportVector.ui'
>> # Created by: PyQt5 UI code generator 5.15.7
>> # WARNING: Any manual changes made to this file will be lost when pyuic5 is
>> # run again. Do not edit this file unless you know what you are doing.
>> from PyQt5 import QtCore, QtGui, QtWidgets
>> class Ui_DbManagerDlgExportVector(object):
>> def setupUi(self, DbManagerDlgExportVector):
>> DbManagerDlgExportVector.setObjectName("DbManagerDlgExportVector")
>> DbManagerDlgExportVector.resize(514, 253)
>> self.gridLayout_2 = QtWidgets.QGridLayout(DbManagerDlgExportVector)
>> self.gridLayout_2.setObjectName("gridLayout_2")
>> self.editOutputFile = QtWidgets.QLineEdit(DbManagerDlgExportVector)
>> self.editOutputFile.setText("")
>> self.editOutputFile.setObjectName("editOutputFile")
>> self.gridLayout_2.addWidget(self.editOutputFile, 1, 1, 1, 1)
>> self.buttonBox = QtWidgets.QDialogButtonBox(DbManagerDlgExportVector)
>> self.buttonBox.setOrientation(QtCore.Qt.Horizontal)
>> self.buttonBox.setStandardButtons(QtWidgets.QDialogButtonBox.Cancel|QtWidgets.QDialogButtonBox.Ok)
>> self.buttonBox.setObjectName("buttonBox")
>> self.gridLayout_2.addWidget(self.buttonBox, 3, 0, 1, 3)
>> self.cboFileFormat = QtWidgets.QComboBox(DbManagerDlgExportVector)
>> self.cboFileFormat.setObjectName("cboFileFormat")
>> self.gridLayout_2.addWidget(self.cboFileFormat, 0, 1, 1, 2)
>> self.label_5 = QtWidgets.QLabel(DbManagerDlgExportVector)
>> sizePolicy = QtWidgets.QSizePolicy(QtWidgets.QSizePolicy.Fixed, QtWidgets.QSizePolicy.Preferred)
>> sizePolicy.setHorizontalStretch(0)
>> sizePolicy.setVerticalStretch(0)
>> sizePolicy.setHeightForWidth(self.label_5.sizePolicy().hasHeightForWidth())
>> self.label_5.setSizePolicy(sizePolicy)
>> self.label_5.setObjectName("label_5")
>> self.gridLayout_2.addWidget(self.label_5, 1, 0, 1, 1)
>> self.groupBox_2 = QtWidgets.QGroupBox(DbManagerDlgExportVector)
>> self.groupBox_2.setObjectName("groupBox_2")
>> self.gridLayout = QtWidgets.QGridLayout(self.groupBox_2)
>> self.gridLayout.setObjectName("gridLayout")
>> self.chkDropTable = QtWidgets.QCheckBox(self.groupBox_2)
>> self.chkDropTable.setObjectName("chkDropTable")
>> self.gridLayout.addWidget(self.chkDropTable, 2, 0, 1, 2)
>> self.horizontalLayout = QtWidgets.QHBoxLayout()
>> self.horizontalLayout.setObjectName("horizontalLayout")
>> self.chkSourceSrid = QtWidgets.QCheckBox(self.groupBox_2)
>> self.chkSourceSrid.setObjectName("chkSourceSrid")
>> self.horizontalLayout.addWidget(self.chkSourceSrid)
>> self.editSourceSrid = QtWidgets.QLineEdit(self.groupBox_2)
>> self.editSourceSrid.setEnabled(False)
>> self.editSourceSrid.setText("")
>> self.editSourceSrid.setObjectName("editSourceSrid")
>> self.horizontalLayout.addWidget(self.editSourceSrid)
>> spacerItem = QtWidgets.QSpacerItem(40, 20, QtWidgets.QSizePolicy.Fixed, QtWidgets.QSizePolicy.Minimum)
>> self.horizontalLayout.addItem(spacerItem)
>> self.chkTargetSrid = QtWidgets.QCheckBox(self.groupBox_2)
>> self.chkTargetSrid.setObjectName("chkTargetSrid")
>> self.horizontalLayout.addWidget(self.chkTargetSrid)
>> self.editTargetSrid = QtWidgets.QLineEdit(self.groupBox_2)
>> self.editTargetSrid.setEnabled(False)
>> self.editTargetSrid.setText("")
>> self.editTargetSrid.setObjectName("editTargetSrid")
>> self.horizontalLayout.addWidget(self.editTargetSrid)
>> self.gridLayout.addLayout(self.horizontalLayout, 0, 0, 1, 2)
>> self.chkEncoding = QtWidgets.QCheckBox(self.groupBox_2)
>> self.chkEncoding.setObjectName("chkEncoding")
>> self.gridLayout.addWidget(self.chkEncoding, 1, 0, 1, 1)
>> self.cboEncoding = QtWidgets.QComboBox(self.groupBox_2)
>> self.cboEncoding.setEnabled(False)
>> sizePolicy = QtWidgets.QSizePolicy(QtWidgets.QSizePolicy.Expanding, QtWidgets.QSizePolicy.Fixed)
>> sizePolicy.setHeightForWidth(self.cboEncoding.sizePolicy().hasHeightForWidth())
>> self.cboEncoding.setSizePolicy(sizePolicy)
>> self.cboEncoding.setEditable(False)
>> self.cboEncoding.setInsertPolicy(QtWidgets.QComboBox.NoInsert)
>> self.cboEncoding.setObjectName("cboEncoding")
>> self.gridLayout.addWidget(self.cboEncoding, 1, 1, 1, 1)
>> self.gridLayout_2.addWidget(self.groupBox_2, 2, 0, 1, 3)
>> self.btnChooseOutputFile = QtWidgets.QToolButton(DbManagerDlgExportVector)
>> self.btnChooseOutputFile.setObjectName("btnChooseOutputFile")
>> self.gridLayout_2.addWidget(self.btnChooseOutputFile, 1, 2, 1, 1)
>> self.label = QtWidgets.QLabel(DbManagerDlgExportVector)
>> self.label.setObjectName("label")
>> self.gridLayout_2.addWidget(self.label, 0, 0, 1, 1)
>> self.retranslateUi(DbManagerDlgExportVector)
>> self.buttonBox.rejected.connect(DbManagerDlgExportVector.reject) # type: ignore
>> self.chkSourceSrid.toggled['bool'].connect(self.editSourceSrid.setEnabled) # type: ignore
>> self.chkTargetSrid.toggled['bool'].connect(self.editTargetSrid.setEnabled) # type: ignore
>> self.chkEncoding.toggled['bool'].connect(self.cboEncoding.setEnabled) # type: ignore
>> self.buttonBox.accepted.connect(DbManagerDlgExportVector.accept) # type: ignore
>> QtCore.QMetaObject.connectSlotsByName(DbManagerDlgExportVector)
>> DbManagerDlgExportVector.setTabOrder(self.chkSourceSrid, self.editSourceSrid)
>> DbManagerDlgExportVector.setTabOrder(self.editSourceSrid, self.chkEncoding)
>> DbManagerDlgExportVector.setTabOrder(self.chkEncoding, self.cboEncoding)
>> DbManagerDlgExportVector.setTabOrder(self.cboEncoding, self.buttonBox)
>> def retranslateUi(self, DbManagerDlgExportVector):
>> _translate = QtCore.QCoreApplication.translate
>> DbManagerDlgExportVector.setWindowTitle(_translate("DbManagerDlgExportVector", "Export to vector file"))
>> self.label_5.setText(_translate("DbManagerDlgExportVector", "Save as"))
>> self.groupBox_2.setTitle(_translate("DbManagerDlgExportVector", "Options"))
>> self.chkDropTable.setText(_translate("DbManagerDlgExportVector", "Replace destination file (if exists)"))
>> self.chkSourceSrid.setText(_translate("DbManagerDlgExportVector", "Source SRID"))
>> self.chkTargetSrid.setText(_translate("DbManagerDlgExportVector", "Target SRID"))
>> self.chkEncoding.setToolTip(_translate("DbManagerDlgExportVector", "Output file encoding"))
>> self.chkEncoding.setText(_translate("DbManagerDlgExportVector", "Encoding"))
>> self.btnChooseOutputFile.setText(_translate("DbManagerDlgExportVector", "…"))
>> self.label.setText(_translate("DbManagerDlgExportVector", "Format"))
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
