[QGIS-Developer] How to enable debugging mode on QGIS start in Win11
Vedran Stojnović phidrho at gmail.com
Tue Jun 20 07:18:45 PDT 2023
I just installed QGIS 3.30.3 via web installer ("qgis-full" version) and
QGIS won't start at all, nor does throw any error when I start it from
PowerShell by executing "qgis-bin.exe".
I tried reinstalling a few times using different servers (default one and
norbit.de) and I also cleaned the cache folder before changing the server.
I already tried adding these two lines to "qgis-bin.env" and I
created "qgislog.txt" on the desktop, but I still do not get any output to
the command line and txt file is empty after trying to start qgis:
QGIS_DEBUG=9
QGIS_LOG_FILE=C:\Users\phidr\Desktop\qgislog.txt
so the current contents of "qgis-bin.env" is:
PATH=C:\OSGeo4W\apps\qgis\bin;C:\OSGeo4W\apps\grass\grass82\lib;C:\OSGeo4W\apps\grass\grass82\bin;C:\OSGeo4W\apps\qt5\bin;C:\OSGeo4W\apps\Python39\Scripts;C:\OSGeo4W\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\WBem
GDAL_DATA=C:\OSGeo4W\apps\gdal\share\gdal
GDAL_DRIVER_PATH=C:\OSGeo4W\apps\gdal\lib\gdalplugins
GDAL_FILENAME_IS_UTF8=YES
PDAL_DRIVER_PATH=C:\OSGeo4W\apps\pdal\plugins
GISBASE=C:\OSGeo4W\apps\grass\grass82
GRASS_PROJSHARE=C:\OSGeo4W\share\proj
GRASS_PYTHON=C:\OSGeo4W\bin\python3.exe
OSGEO4W_ROOT=C:\OSGeo4W
PROJ_LIB=C:\OSGeo4W\share\proj
PYTHONHOME=C:\OSGeo4W\apps\Python39
PYTHONPATH=C:\OSGeo4W\apps\grass\grass82\etc\python;
PYTHONUTF8=1
QGIS_PREFIX_PATH=C:/OSGeo4W/apps/qgis
QT_PLUGIN_PATH=C:\OSGeo4W\apps\qgis\qtplugins;C:\OSGeo4W\apps\qt5\plugins
VSI_CACHE=TRUE
VSI_CACHE_SIZE=1000000
O4W_QT_PREFIX=C:/OSGeo4W/apps/Qt5
O4W_QT_BINARIES=C:/OSGeo4W/apps/Qt5/bin
O4W_QT_PLUGINS=C:/OSGeo4W/apps/Qt5/plugins
O4W_QT_LIBRARIES=C:/OSGeo4W/apps/Qt5/lib
O4W_QT_TRANSLATIONS=C:/OSGeo4W/apps/Qt5/translations
O4W_QT_HEADERS=C:/OSGeo4W/apps/Qt5/include
QGIS_WIN_APP_NAME=OSGeo4W\QGIS Desktop 3.30.3
SSL_CERT_DIR=C:\OSGeo4W\apps\openssl\certs
SSL_CERT_FILE=C:\OSGeo4W\bin\curl-ca-bundle.crt
QGIS_DEBUG=9
Kind regards,
Vedran Stojnović.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230620/ae249e19/attachment.htm>
More information about the QGIS-Developer mailing list
