[QGIS-Developer] Timestep for (Temporal) Mesh/netcdf layers?
Richard Duivenvoorde
rdmailings at duif.net
Wed Mar 8 06:42:18 PST 2023
Ok, found it. It is in the temporalCapabilities...
So given a loaded netcdf/mesh with time.
Easiest is the firstTimeStepDuration(i) of QgsMeshDataProviderTemporalCapabilities:
>>> p = iface.activeLayer().dataProvider().temporalCapabilities()
>>> p
<qgis._core.QgsMeshDataProviderTemporalCapabilities object at 0x7fa958267e20>
>>> p.timeExtent()
<QgsDateTimeRange:[2022-11-07T07:00:00Z, 2022-11-08T06:00:00Z]>
>>> p.temporalUnit()
<TemporalUnit.Hours: 3> <<< ?????
# datasetTime() Returns the relative time in milliseconds of the dataset
>>> p.datasetTime(QgsMeshDatasetIndex(0,0))
3600000
>>> p.datasetTime(QgsMeshDatasetIndex(0,1))
7200000
>>> p.datasetTime(QgsMeshDatasetIndex(0,2))
10800000
# firstTimeStepDuration() Returns the duration of the first time step of the dataset group with index \a group
# in milliseconds
p.firstTimeStepDuration(0)
3600000 == 3600 s = 1 hours
21600000 == 21600 s == 360 minute == 6 hours
Only strange thing is that the temporalUnit() always returns 'hours', while the actual data time is relative in minutes...
Regards,
On 3/7/23 14:18, Richard Duivenvoorde via QGIS-Developer wrote:
> Hi,
> When loading (temporal) Netcdf files (as MeshLayers), the 'timestep' that you see in the Temporal Controller does not change.
> I had a look at the api, but could not find any indication of knowledge by the QgsMeshLayer of the size of the timesteps of the data.
> Within netcdf's it is common to define the timesteps as something like:
> "minutes since 2022-11-27 16:00:00.0Z"
> then the first set has 0, and then the next one for example 60 for hourly data or 10 for 10-minute data.
> Question: IS a temporal mesh layer aware of the timesteps used?
> Or if not: I seem not to be able to inspect the data array of the 'time' dimension. Should/can I?
> IF so, we could we could deduct from the first 2 or 3 timesteps, the size of the timestep.
> Anybody a hint or idea?
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
