[QGIS-Developer] Search and Rescue Package
Jan Růžička
jan.ruzicka.vsb at gmail.com
Thu Mar 16 05:24:04 PDT 2023
Hi. I have developed a plugin for SAR operations for Police of the Czech
Republic.
You can check it at http://patrac.eu
Here is the User manual (only in czech language, but with some images that
may show how it works): http://sarops.info/patrac/qgis3/user/index.html
or here is the presentation from 2021 done for Slovenia Mountain Rescue
Service (http://sarops.info/patrac/qgis3/prezentace/Patrac202104_EN.pdf).
Now I am in the process of making it more generic to be working anywhere in
the world.
If you are interested, you can contact me.
Best regards
Jan Růžička, Ph.D.
freelancer, researcher and volontaire
Geoinformatics
tel: +420 775 032 091
e-mail: jan.ruzicka.vsb at gmail.com <http://jan.ruzicka.vsb.cz/>
http://github.com/ruz76/
http://patrac.eu/
http://cybele.space/
http://gismentors.eu/
http://dolnilhota.info/
Le jeu. 16 mars 2023 à 13:03, John Hutcheson via QGIS-Developer <
qgis-developer at lists.osgeo.org> a écrit :
> Many thanks to Richard Dulvenvoorde for helping me connect with the
> Developer community.
> Greetings from Michigan!
> I work on a search and rescue team that wishes to move to QGIS for use in
> printing maps, deploying teams to search segments of the search area, and
> tracking clues / search assets. I have already used the system (3.2) as it
> is today and find it to be far superior to what we have used in the past.
> In preparation for this, we have obtained sat maps and topos of the lower
> peninsula of Michigan (our coverage area) and will shortly obtain street
> maps covering the same area to develop the appropriate layers for our maps.
> After a short search of the available packages for the system, I don’t see
> any that match our needs, though I’ve just been using the search terms I am
> familiar with, and being a newbie, could have easily missed something. I
> don’t expect what we need will have much application or be of interest to
> others, so I won’t be surprised if we need to start from scratch. What I
> would like is some ideas of existing packages I can steal shamelessly from
> to build what we need. Or if it already exists, a push to the right
> package(s) or the right user group that may already cover this turf.
> I see you have all the tools we will need for our maps (except perhaps
> grid convergence), which should make this relatively easy. I don’t see any
> packages that are scripted to walk through the process we currently use to
> define search areas using R. Koester’s behavioral category rings. And so I
> am committed to developing a script todo this in our first phase of
> development.
> Our plan is to develop a script that will:
> 1. Define the IPP (initial Planning Point) for the search and mark
> the map accordingly
> 2. Mark other search assets (Staging / Incident Command / Net
> Control, etc)
> 3. Constrain the visible / map area to the 95th percentile of
> Probability of Area (or Containment).
> 4. Place Koester rings on the map for the 25 / 50 / 75 / 95 POAs and
> for our 300m initial search area.
> 5. Index all maps with magnetic declination and grid convergence for
> our navigator's easy reference
> 6. Save PDF versions of the SAT/TOPO/Street maps to a remote folder
> for retrieval as the search progresses.
> 1. At various scales and indexed for retrieval by area / scale
> If this works as I hope, we will begin planning work on a second phase to
> use automation to segment the search area into acceptable chunks a ground
> team or canine team can tackle in a given working period.
> Any help is appreciated.
> Have fun,
> John Hutcheson
> Midland County Search and Rescue
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230316/334d08fe/attachment.htm>
