[QGIS-Developer] Tool to create Mesh from raster layer?
Andreas Neumann
a.neumann at carto.net
Mon Mar 20 06:31:35 PDT 2023
and there seems to be https://github.com/heremaps/tin-terrain
However, I am looking for a solution integrated in QGIS ...
On 2023-03-20 14:28, Andreas Neumann via QGIS-Developer wrote:
> Hi,
> Yes - exporting the raster to xyz points or to contour lines are both
> workarounds.
> It would be nice, if QGIS would gain a direct algorithm of creating a
> mesh from a DEM - as many DTMs are provided as raster. It seems like
> SAGA has a raster DTM to TIN algorithm (
> https://saga-gis.sourceforge.io/saga_tool_doc/8.5.1/tin_tools_0.html )
> - but SAGA is a bit complicated to use within QGIS and SAGA support
> within QGIS processing may disappear in the future. Perhaps we could
> port the SAGA algorithm to QGIS - or maybe an alternative algorithm?
> My goal is to replace the raster DTM with a MESH for 3D display - with
> the ability to edit the MESH at important points. The builtin
> triangulation of the QGIS 3D viewer (where you can have a raster DTM as
> a terrain source) is sometimes doing weird things - I'd like to control
> that better - e.g. by introducing additional break lines or manually
> editing the Mesh.
> Andreas
> On 2023-03-20 14:20, Stefan Giese (WhereGroup) via QGIS-Developer
> wrote:
> Hi all,
> I think it is not nessasary to go through Blender, just use theese two
> algorithm:
> * pixeltopoints
> * tinmeshcreation
> Best regards
> Stefan
> Am 20.03.2023 um 14:11 schrieb Sebastian Gutwein via QGIS-Developer:
> The ridiculous work around I use is to go through Blender using the
> BlenderGIS plugin. Import the raster into Blender as a new mesh >
> Decimate the mesh > Export as a shapefile > Run TIN Mesh Creation in
> QGIS.
> On Mon, Mar 20, 2023 at 9:03 AM Saber Razmjooei via QGIS-Developer
> <qgis-developer at lists.osgeo.org> wrote:
> Hi Andreas,
> There should be a tool to convert vector to mesh (under Processing >
> Mesh > TIN Mesh Creation). There will also be some new Processing tools
> for handling point clouds. But I am not aware of any Raster > Mesh
> tools.
> Kind regards
> Saber
> On Mon, 20 Mar 2023 at 13:56, Andreas Neumann via QGIS-Developer
> Hi QGIS devs,
> Is there a tool available to create a Mesh (or TIN as a special mesh
> variation) from a source raster layer containing terrain values?
> I did not find one - but maybe I didn't look everywhere.
> If not in QGIS - do you know an external Open Source tool that could do
> that, while keeping real world coordinates?
> Thanks,
> Andreas _______________________________________________
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Saber Razmjooei
> www.lutraconsulting.co.uk [1]
> +44 (0)7568 129733 _______________________________________________
Sebastian "Bas* " Gutwein
*rhymes with Josh
Regenerative Design Group
1 Chevalier Ave
Greenfield, Ma 01301
Web: regenerativedesigngroup.com [3]
(631) 241-1018
_Look close, think big, make change. _
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
FOSSGIS Konferenz
15.-18. März 2023 in Berlin
https://fossgis-konferenz.de/2023/
WhereGroup-Beiträge auf der FOSSGIS
https://wheregroup.com/unternehmen/aktuelles/
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Tel.: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
stefan.giese at wheregroup.com
www.wheregroup.com [2]
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Links:
[1] http://www.lutraconsulting.co.uk
[2] http://www.wheregroup.com
[3] http://regenerativedesigngroup.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230320/ad4c3b27/attachment-0001.htm>
