[QGIS-Developer] Tool to create Mesh from raster layer?
Andreas Neumann
andreas at qgis.org
Tue Mar 21 01:07:16 PDT 2023
Hi Saber,
It is a good point - to use the source.
I think the source was a point cloud data set.
So, ideally, it could be a point cloud to mesh tool (or TIN).
I see that Alex Bruy just committed a point cloud to raster tool (going
through TIN is an option), but not as a final TIN result.
Andreas
On Tue, 21 Mar 2023 at 08:42, Saber Razmjooei via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi Andreas,
> Indeed, there is no native tool at the moment to convert raster directly
> to mesh. I filed a ticket with a link to this discussion so we can add it
> to QGIS later:
> https://github.com/qgis/QGIS/issues/52313
> But, in general, I would first try to find the source of the DEM raster
> (e.g. point cloud or spot survey) and use the raw data to create the mesh.
> This will avoid double interpolation :)
> Kind regards
> Saber
> On Mon, 20 Mar 2023 at 14:31, Andreas Neumann via QGIS-Developer <
>> and there seems to be https://github.com/heremaps/tin-terrain
>> However, I am looking for a solution integrated in QGIS ...
>> On 2023-03-20 14:28, Andreas Neumann via QGIS-Developer wrote:
>> Hi,
>> Yes - exporting the raster to xyz points or to contour lines are both
>> workarounds.
>> It would be nice, if QGIS would gain a direct algorithm of creating a
>> mesh from a DEM - as many DTMs are provided as raster. It seems like SAGA
>> has a raster DTM to TIN algorithm (
>> https://saga-gis.sourceforge.io/saga_tool_doc/8.5.1/tin_tools_0.html ) -
>> but SAGA is a bit complicated to use within QGIS and SAGA support within
>> QGIS processing may disappear in the future. Perhaps we could port the SAGA
>> algorithm to QGIS - or maybe an alternative algorithm?
>> My goal is to replace the raster DTM with a MESH for 3D display - with
>> the ability to edit the MESH at important points. The builtin triangulation
>> of the QGIS 3D viewer (where you can have a raster DTM as a terrain source)
>> is sometimes doing weird things - I'd like to control that better - e.g. by
>> introducing additional break lines or manually editing the Mesh.
>> Andreas
>> On 2023-03-20 14:20, Stefan Giese (WhereGroup) via QGIS-Developer wrote:
>> Hi all,
>> I think it is not nessasary to go through Blender, just use theese two
>> algorithm:
>> - pixeltopoints
>> - tinmeshcreation
>> Best regards
>> Stefan
>> Am 20.03.2023 um 14:11 schrieb Sebastian Gutwein via QGIS-Developer:
>> The ridiculous work around I use is to go through Blender using the
>> BlenderGIS plugin. Import the raster into Blender as a new mesh > Decimate
>> the mesh > Export as a shapefile > Run TIN Mesh Creation in QGIS.
>> On Mon, Mar 20, 2023 at 9:03 AM Saber Razmjooei via QGIS-Developer <
>> Hi Andreas,
>> There should be a tool to convert vector to mesh (under Processing > Mesh
>> > TIN Mesh Creation). There will also be some new Processing tools for
>> handling point clouds. But I am not aware of any Raster > Mesh tools.
>> Kind regards
>> Saber
>> On Mon, 20 Mar 2023 at 13:56, Andreas Neumann via QGIS-Developer <
>> Hi QGIS devs,
>> Is there a tool available to create a Mesh (or TIN as a special mesh
>> variation) from a source raster layer containing terrain values?
>> I did not find one - but maybe I didn't look everywhere.
>> If not in QGIS - do you know an external Open Source tool that could do
>> that, while keeping real world coordinates?
>> Thanks,
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Saber Razmjooei
>> www.lutraconsulting.co.uk
>> +44 (0)7568 129733
>> Sebastian "Bas* " Gutwein
>> *rhymes with Josh
>> Regenerative Design Group
>> 1 Chevalier Ave
>> Greenfield, Ma 01301
>> Web: regenerativedesigngroup.com
>> (631) 241-1018
>> *Look close, think big, make change. *
>> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
>> Mit freundlichen Grüßen
>> Stefan Giese
>> Projektleiter/Consultant
>> FOSSGIS Konferenz
>> 15.-18. März 2023 in Berlinhttps://fossgis-konferenz.de/2023/
>> WhereGroup-Beiträge auf der FOSSGIShttps://wheregroup.com/unternehmen/aktuelles/
>> WhereGroup GmbH
>> Schwimmbadstr. 2
>> 79100 Freiburg
>> Germany
>> Tel.: +49 (0)761 / 519 102 - 61
>> Fax: +49 (0)761 / 519 102 - 11
>> stefan.giese at wheregroup.comwww.wheregroup.com
>> Geschäftsführer:
>> Olaf Knopp, Peter Stamm
>> Amtsgericht Bonn, HRB 9885
> Saber Razmjooei
> +44 (0)7568 129733
Andreas Neumann
QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230321/964e6c1e/attachment.htm>
