[QGIS-Developer] access virtual field from virtual layer
Hugh Kelley hghklly at gmail.com
Fri Mar 24 06:19:42 PDT 2023
is it expected that a virtual layer cannot reference a virtual field from
an imported layer?
Using 3.28 if I create a virtual field on a shp sourced layer and then
import that layer into the virtual layer creator dialogue and set the query
to "select * from vfield_layer". the virtual field in the original layer is
not included in the new virtual layer's attribute table.
thanks!
Hugh
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230324/cfcf9961/attachment.htm>
More information about the QGIS-Developer mailing list
