[QGIS-Developer] No module named 'qgslayoutchecker' using "qgis/qgis:latest"
DelazJ
delazj at gmail.com
Tue May 2 01:02:06 PDT 2023
Hi Paolo,
Yes, we do have the same problems with testing in QGIS-Documentation
repository, for everything related to master branch (
https://github.com/qgis/QGIS-Documentation/actions/workflows/doctest.yml?query=branch%3Amaster).
3.28 is fine.
Regards,
Harrissou
Le mar. 2 mai 2023 à 08:44, Paolo Tormene via QGIS-Developer <
qgis-developer at lists.osgeo.org> a écrit :
> Dear QGIS people,
> I am running continuous integration tests for a plugin using the
> 'qgis/qgis:latest' docker and, since 4 days ago, I am getting the following
> error:
> from qgis.testing import start_app
> usr/lib/python3/dist-packages/qgis/utils.py:888: in _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> usr/lib/python3/dist-packages/qgis/testing/__init__.py:56: in <module>
> from qgslayoutchecker import QgsLayoutChecker
> E ModuleNotFoundError: No module named 'qgslayoutchecker'
> Please note that the same tests run without issues using the
> 'qgis/qgis:release-3_22' docker instead.
> Has anyone experienced the same problem?
> Thank you and best regards,
> Paolo
> *PAOLO TORMENE* senior software developer +39 0382 5169882
> *GLOBAL EARTHQUAKE MODEL * working together to assess risk
> *GEM -* globalquakemodel.org <http://www.globalquakemodel.org> *T -*
> @GEMwrld <http://twitter.com/GEMwrld> *F -* GEMwrld
> <http://www.facebook.com/GEMwrld>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230502/9dba2681/attachment-0001.htm>
