[QGIS-Developer] Profiler times in Python
Etienne Trimaille
etienne.trimaille at gmail.com
Fri May 5 05:03:23 PDT 2023
One line I know, maybe this is enough :
>>> from qgis.utils import plugin_times
>>> plugin_times
It's not using the profiler. Values are different from the Profiler, after
a quick look...
Le ven. 5 mai 2023 à 10:21, Michel Stuyts via QGIS-Developer <
qgis-developer at lists.osgeo.org> a écrit :
> I want to use the data on plugins from the Profiler. In the
> “Debugging/Development Tools” Panel I can see both the total time for all
> plugins and the individual time per plugin. With the following Python
> code, I want to get the same data in Python:
> profiler = QgsApplication.profiler()
> for child in profiler.childGroups():
> childGroup = profiler.childGroups(child)
> if child == 'Load plugins':
> print(child, profiler.profileTime(child))
> for subGroup in childGroup:
> print(subGroup, profiler.profileTime(subGroup))
> It shows the total time for all plugins just fine as “Load plugins” with
> the same number of seconds as in the Panel, but for the individual plugins
> I get 0.0 as time for all plugins. What do I do wrong or is it a bug?
> Michel Stuyts
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230505/6c4f31a6/attachment.htm>
