[QGIS-Developer] Best practice for plugins including processing models
Alister Hood
alister.hood at gmail.com
Mon May 15 19:09:38 PDT 2023
And including this in loadModels() is a fairly safe way to remove the
copied model files from previous versions:
modelsFiles = glob.glob(os.path.join(self.modelsPath,
'*.model3'))
for modelFileName in modelsFiles:
destFilename =
os.path.join(ModelerUtils.defaultModelsFolder(),
os.path.basename(modelFileName))
try:
if os.path.exists(destFilename):
move(destFilename, destFilename + '.bak')
except Exception as ex:
QgsMessageLog.logMessage(self.tr('Failed to rename
existing model: {} - {}'.format(destFilename, str(ex))), self.messageTag,
Qgis.Warning)
continue
It does mean that if someone happens to have a model with the same name as
one provided by the plugin, it will disappear, but at least it will still
be there as a *.bak file, rather than just being overwritten.
On Tue, 16 May 2023 at 13:19, Alister Hood <alister.hood at gmail.com> wrote:
> Further to this, I am now using the following code to load the models
> directly from the plugin folder, rather than copying them into
> %AppData%\Roaming\QGIS\QGIS3\profiles\default\processing\models
> def loadModels(self):
> modelsFolders=ModelerUtils.modelsFolders()
> if self.modelsPath not in modelsFolders:
> modelsFolders.append(self.modelsPath)
> ProcessingConfig.setSettingValue(ModelerUtils.MODELS_FOLDER,
> ';'.join(modelsFolders))
> QgsApplication.processingRegistry().providerById('model').refreshAlgorithms()
> def unloadModels(self):
> if self.modelsPath in modelsFolders:
> modelsFolders.remove(self.modelsPath)
> On Fri, 28 Apr 2023 at 15:07, Alister Hood <alister.hood at gmail.com> wrote:
>> Hi, I maintain an in-house plugin for our team of civil engineers, who
>> apart from myself are not very advanced GIS users.
>> It does things like set useful defaults and install a set of useful
>> plugins. It also includes some processing models, which are loaded with
>> the code below, which seems to be the conventional way models are loaded in
>> publicly available plugins which ship processing models. This code copies
>> the model files included in the plugin to the default folder for processing
>> models - somewhere like
>> One of my colleagues did some QGIS training and created a processing
>> model, which coincidentally had the same filename as a model I created on
>> the same day, so his model got overwritten when my plugin was updated.
>> This is not a problem for us as we are a small team and can be careful what
>> we do going forward. But it highlights that the way plugin authors are
>> loading model files is what seems to me to be pretty poor practice, for two
>> reasons.
>> Firstly models are available in qgis even when the plugin is unloaded or
>> uninstalled, which is probably not desirable.
>> It is trivial to implement an unloadModels function to rectify this, and
>> I have done so in my in-house plugin. I'm wondering - should plugin
>> authors be encouraged to do the same?
>> Secondly, loading the plugin will silently overwrite any existing models
>> with the same filename, as occurred here. Plugins generally contain models
>> with fairly special filenames, so hopefully this is unlikely to occur,
>> unless:
>> - someone produces a plugin that is a fork of another one, or
>> - someone ships a plugin with a model that is previously publicly
>> available somewhere else, or that was created by following an online
>> tutorial, or
>> - a user edits a model provided by a plugin.
>> In any case, would it be a good idea to encourage plugin authors to load
>> models another way, without copying them into
>> %AppData%\Roaming\QGIS\QGIS3\profiles\default\processing\models?
>> I realise that to change an existing plugin there is the added
>> complication of what to do when updating from an old version - the only
>> safeish way I can think of to automatically clean up obsolete model files
>> would be to check for them and then use a checksum to verify whether they
>> should be deleted.
>> For what it's worth, I note that when a user tries to manually "add model
>> to toolbox", QGIS refuses if there is an existing model with the same
>> filename.
>> Thanks.
>> '''Register models present in models folder of the plugin.'''
>> try:
>> iface.initializationCompleted.disconnect(self.loadModels)
>> except:
>> pass
>> #QgsMessageLog.logMessage(self.tr('testing'),
>> self.messageTag, Qgis.Warning)
>> '*.model3'))
>> alg = QgsProcessingModelAlgorithm()
>> if not alg.fromFile(modelFileName):
>> QgsMessageLog.logMessage(self.tr('Not well formed
>> model: {}'.format(modelFileName)), self.messageTag, Qgis.Warning)
>> continue
>> destFilename =
>> os.path.join(ModelerUtils.modelsFolders()[0],
>> try:
>> os.remove(destFilename)
>> if isWindows():
>> copyfile(modelFileName, destFilename)
>> else:
>> os.symlink(modelFileName, destFilename)
>> QgsMessageLog.logMessage(self.tr('Failed to install
>> model: {} - {}'.format(modelFileName, str(ex))), self.messageTag,
>> Qgis.Warning)
>> continue
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230516/c3934f68/attachment-0001.htm>
