[QGIS-Developer] Lazy question about using views in GeoPackages
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Fri May 26 03:52:56 PDT 2023
Hi list -
Recently, I've begun experimenting with creating spatial view's of
base-tables inside GeoPackages. A Geopackage is basically a SQLite file
containing spatial data- and meta-tables with specific structures of
information about the spatial tables.
So it's possible to create a permanent view of a table (or tables) in
the GeoPackage by making a functioning SQL select statement and
prefixing it with "CREATE VIEW /view_name/ AS .. /the select statement/
.. (This is database 101 knowledge)
However, if you want to expose those views as "read-only" tables/layers
for "non-sql-using" QGIS users you have to update several meta-tables
in the GeoPackage: /gpkg_contents/, /gpkg_geometry_columns/ and maybe
/gpkg_ogr_contents/.
I'm brainstorming with myself about making some kind of automated
updating of the meta-tables with information about the views created.
Maybe some python code and maybe creating triggers for the base table to
handle data changes regarding the extend of the data.
And now (at last !!) my question: I haven't been able to find very much
information about this subject using Google or StackExchange. So.. Is
there some existing code / plugin / information so I don't have to
"reinvent the wheel" ?
Med venlig hilsen / Best regards
Bo Victor Thomsen
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230526/b29f1266/attachment.htm>
