[QGIS-Developer] Next QGIS LTR and its compatibility with older versions
Andreas Neumann
a.neumann at carto.net
Mon Oct 2 07:07:39 PDT 2023
Hi Raffael,
3.34 will be the next LTR, but not yet in October 2023, but only
starting from end of February 2024. In the table
https://qgis.org/en/site/getinvolved/development/roadmap.html#release-schedule
you can check the third column labeled "Long-Term Repo" to see at what
time frame which version is LTR.
About your second question: don't nail me down on this but all 3.x
versions should open with the newest 3.x version - it should be even
possible to open version 2 files with the latest 3.x version.
Greetings,
Andreas
On 2023-10-02 15:57, Raffael Meier via QGIS-Developer wrote:
> Hello
> I would like to know if this is correct, that the next long term
> release of a stable QGIS version (3.34.0) will be at the end of October
> 2023?
> If this is correct I would like to know if I worked with an older
> version and I want to continue working on this project with the
> upcoming LTR what ist he oldest QGIS version files that
> I can still use with the new LTR (3.34.0).
> Best regards,
> Raffael
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231002/ef293076/attachment.htm>
