[QGIS-Developer] pygdaltools library documentation sparce
Catania, Luke A ERDC-RDE-GRL-VA CIV
Luke.A.Catania at erdc.dren.mil
Tue Oct 10 22:15:17 PDT 2023
I am running simple code to convert dxf to gpkg and I get the error below. -am an trying to figure eout how to add a bunch of options ( -f GPKG -append -update --config DXF_ENCODING CP1252 --config DXF_INCLUDE_RAW_CODE_VALUES TRUE --config DXF_TRANSLATE_ESCAPE_SEQUENCES FALSE --config DXF_MERGE_BLOCK_GEOMETRIES FALSE --config DXF_INLINE_BLOCKS TRUE -nlt LINESTRING -nln 32111_F
But can't even figure out how to add the recommended skipfailures. I tried adding
gdal_tools.config_options("-skipfailures")
but I get pyling tells me it is not callable.
Anyone use pygdaltools?
import gdaltools
gdal_tools = gdaltools.ogr2ogr()
gdal_tools.BASEPATH = r"C:\Program Files\QGIS 3.16.16\bin"
gdal_tools.set_encoding("UTF-8")
gdal_tools.set_input(self.dxf_out_path)
gdal_tools.set_output(self.gpkg_out)
gdal_tools.execute()
And I get the ERROR:root:b"Warning 1: Layer creation options ignored since an existing layer is\r\n being appended to.\r\nWarning 6: Normalized/laundered field name: 'EntityHandle' to 'EntityHa_2'\r\nERROR 1: Attempt to write non-linestring (GEOMETRYCOLLECTION) geometry to ARC type shapefile.\r\nERROR 1: Unable to write feature 0 from layer entities.\r\nERROR 1: Terminating translation prematurely after failed\r\ntranslation of layer entities (use -skipfailures to skip errors)\r\n"
File "c:\Users\RDTECLAC\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\site_selection\tools\master_planning\load_mp_designs.py", line 227, in <module>
main()
File "c:\Users\RDTECLAC\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\site_selection\tools\master_planning\load_mp_designs.py", line 196, in main
mp_designs.gdal_convert()
File "c:\Users\RDTECLAC\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\site_selection\tools\master_planning\load_mp_designs.py", line 185, in gdal_convert
File "C:\Users\RDTECLAC\AppData\Roaming\Python\Python39\site-packages\gdaltools\ogr2ogrcmd.py", line 330, in execute
return self._do_execute(args)
File "C:\Users\RDTECLAC\AppData\Roaming\Python\Python39\site-packages\gdaltools\basetypes.py", line 108, in _do_execute
raise GdalToolsError(rc, err)
gdaltools.basetypes.GdalToolsError: (1, b"Warning 1: Layer creation options ignored since an existing layer is\r\n being appended to.\r\nWarning 6: Normalized/laundered field name: 'EntityHandle' to 'EntityHa_2'\r\nERROR 1: Attempt to write non-linestring (GEOMETRYCOLLECTION) geometry to ARC type shapefile.\r\nERROR 1: Unable to write feature 0 from layer entities.\r\nERROR 1: Terminating translation prematurely after failed\r\ntranslation of layer entities (use -skipfailures to skip errors)\r\n")error:
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231011/64c9d7a7/attachment.htm>
