[QGIS-Developer] Dropping "render" checkbox from status bar
steven kay
stevendkay at gmail.com
Sun Oct 15 12:59:31 PDT 2023
Yes! I find this useful, sometimes.
Use case: Sometimes I'll use the Db manager to write a query which I add as
a view. With a few million points. Said layer is created dynamically, so it
takes a while to render with the default symbology.
If I can turn off rendering, I don't need to wait for ages for it to
render, I can select the layer and export it as a GPKG, and then import it.
At no point does QGIS GUI become unresponsive - I can just uncheck the box.
I just don't want to wait around for a render I don't need
I hope that makes sense! I'm sure there's a better way in QGIS I'm not
aware of :)
Steven
On Sun, Oct 15, 2023 at 8:39 PM Vedran Stojnović via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi Nyall,
> I find it useful from time to time with complex layer rendering when it
> takes several seconds or more to render a map canvas and I want to
> investigate attributes currently shown on screen.
> My procedure is as follows:
> 1) zoom at the appropriate level and lock rendering
> 2) open the attribute table and set it to display items visible on the map
> 3) move around the map zooming in and out and analyzing the results
> ned, 15. lis 2023. u 21:30 Nyall Dawson via QGIS-Developer <
> qgis-developer at lists.osgeo.org> napisao je:
>> Hi list,
>> Question: are there still any valid use cases for the "render"
>> checkbox in the status bar? It's been around forever, and DID have a
>> strong use case when map rendering used to block the QGIS interface.
>> But is there any reason to keep this around in modern QGIS versions?
>> Nyall
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Srdačan pozdrav / Kind regards,
> Vedran Stojnović.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231015/d8cdf0f7/attachment.htm>
