[QGIS-Developer] QGIS repository management
Nyall Dawson
nyall.dawson at gmail.com
Sun Oct 15 13:04:38 PDT 2023
> A small group of us (3-4 developers including me) have admin access to
> all QGIS repositories and we can bypass any check and merge all PRs
> without approval.
I have this power too -- and I use it on a daily basis to keep the whole CI
setup flowing (ie restarting workflows in other's PRs, merging approved PRs
when an unrelated workflow failure has blocked a merge, etc).
I'd like to point out that it's only used to keep the project humming along
for EVERYONE's benefit -- it's not a conspiracy to create a set of "super
committers" with extra power 😂 .
Nyall
> I admit that I have been using these superpowers more and more often
> (IIRC three or four times) in the last year while I have never felt
> the need to use them before, in an ideal world it should not be
> necessary except for the same use cases I have pointed out for the
> direct pushes to master.
> The bottom line is that the situation is not perfect and can certainly
> be improved but at the end of the day we are all doing our best to
> keep the process running as smoothly as we can.
> Thank you for raising this point, you are absolutely right that it
> should be clearly documented, this has been in our TODO list for a
> long time.
> Best regards.
> On Fri, Oct 13, 2023 at 6:42 PM Sandro Santilli via QGIS-Developer
> <qgis-developer at lists.osgeo.org> wrote:
> > Hello all,
> > today I was finally able to more clearly see the problem that frustrates
> > me everytime a take part to a new QGIS bugfixing drive, and I would like
> > to share it hoping to find a solution togheter.
> > The main problem:
> > - Despite having been granted write access to the QGIS repository in
2012
> > [1], I cannot effectively use that power today
> > It's not just me, I think, but I cannot tell for sure because the
configuration
> > of the infrastructure currently in use (github) is not available for me
to see
> > and the governance page on the official QGIS website does not contain
this
> > information [2]. This being blind of course adds up to my frustration.
> > From experience, I know that the reason why I cannot write to the QGIS
> > repository is because "branch protection" is active (for the master
branch
> > at least) and a set of conditions are required to merge a PR, namely:
> > - All CI tests need to pass.
> > - Someone else (I don't know from which group of people) needs to
> > approve the proposed change.
> > While I do the above condition being a useful indication for "QGIS
> > core developers" to decide whether to accept or not a change request,
> > I find them representing an obstacle way more often than a service,
> > and in particular:
> > 1. CI is often broken for reasons that are independent from the proposed
> > change.
> > 2. An aberration of the "review" condition is that a change proposed by
a
> > contributor and approved by me can be merged but a change proposed by
> > me and approved by the same contributor can not be merged,
effectively
> > giving me ("core QGIS committer") less power than the power of a
random
> > contributor.
> > The rules described above are not found from the governance page [2]
> > so it isn't easy for me to propose changes because I don't have a clear
> > picture of current rules (like, I believe some people in QGIS can
> > self-approve PRs but dunno how to tell who and why).
> > I would personally welcome (and be able to help taking) the following
actions:
> > 1. Clearly document the roles and rules on the website
> > 2. Allow those with "write access" to self-approve PRs
> > 3. Define rules by which "write access" privileges to the repository
> > are revoked
> > Thanks for having read this in full, and I hope to hear your position
> > on the matter. Happy hacking !
> > [1]
https://lists.osgeo.org/pipermail/qgis-developer/2012-October/022715.html
> > [2] https://qgis.org/en/site/getinvolved/governance/governance.html
> > --strk;
> > Libre GIS consultant/developer
> > https://strk.kbt.io/services.html
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> QCooperative: www.qcooperative.net
> ItOpen: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231016/26f6d199/attachment-0001.htm>
