[QGIS-Developer] pyqgis QgsGeometrySnapper does not snap to a source created inside a function
Gabriel De Luca
pablogabrieldeluca at gmail.com
Thu Oct 19 09:32:31 PDT 2023
Hi German,
Thanks. Yes, it works that way. Do you know why?
Regards,
Gabriel
El jue, 19 oct 2023 a la(s) 13:04, Germán Carrillo (
carrillo.german at gmail.com) escribió:
> Hi Gabriel,
> Does the result change if you first create a Python variable for storing
> your new layer?
> I mean:
> *referenceSource = create_scratch_reference_layer()*
> *snapper = QgsGeometrySnapper(referenceSource)*
> instead of:
> *snapper = QgsGeometrySnapper(*
> * referenceSource=create_scratch_reference_layer()*
> Regards,
> Germán
> El jue, 19 oct 2023 a las 14:46, Gabriel De Luca via QGIS-Developer (<
> qgis-developer at lists.osgeo.org>) escribió:
>> Hello all,
>> I am working with the QgsGeometrySnapper pyqgis class, and have a
>> problem to snap to a reference layer which is created inside a function
>> (and returned by it).
>> The code shared at [1] prints:
>> result = <QgsGeometry: Polygon ((0.10000000000000001
>> -0.10000000000000001, 10.09999999999999964 0, 9.90000000000000036
>> 10.09999999999999964, 0 10, 0.10000000000000001 -0.10000000000000001))>
>> Which means that the geomPolygon was not snapped to the reference layer.
>> But, if uncomment the line 41, which adds the reference layer to the
>> project, the code prints:
>> result = <QgsGeometry: Polygon ((0 0, 10 0, 10 10, 0 10, 0 0))>
>> So, for some reason, adding the reference layer to the project makes
>> the snapper to work.
>> I want to ask you if you know why is this happening. Maybe I need to
>> add something to make it work consistently.
>> Regards,
>> Gabriel
>> [1] https://pastebin.com/raw/Y9v51ZMq
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> |\__
> (:>__)(
> Soluciones Geoinformáticas Libres
> http://geotux.tuxfamily.org/
> https://twitter.com/GeoTux2 <http://twitter.com/GeoTux2>
> <http://gis.stackexchange.com/users/4972/germ%c3%a1n-carrillo>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231019/d1e2359e/attachment.htm>
