[QGIS-Developer] error adding new feature to empy layer
Richard Duivenvoorde
rdmailings at duif.net
Thu Apr 4 01:11:36 PDT 2024
Hi Pierluigi,
Are you sure the creation of the geometry is ok?
Because your code with some hardcoded values in it, just works in my python console:
vl = QgsVectorLayer("LineString", "braiding_river", "memory")
pr = vl.dataProvider()
# add fields
pr.addAttributes([
QgsField("reach", QVariant.String),
QgsField("braiding", QVariant.Double),
QgsField("Length", QVariant.Double)])
vl.updateFields()
print(f"{vl.isValid()=}")
feat_list=[]
fet = QgsFeature()
fet.setGeometry(QgsGeometry.fromWkt('LINESTRING (30 10, 10 30, 40 40)'))
fet.setAttributes([ 'test', 2, 2])
print(f"{fet.isValid()=}")
feat_list.append(fet)
(result, newFeatures) = pr.addFeatures(feat_list)
print(f"{result=}")
print(newFeatures)
Regards,
> vl.setCrs(crs)
> # add fields
> pr.addAttributes([
> vl.updateFields()
> feat_list=[]
> then I populate the layer where inside a for cycle I have
> fet = QgsFeature()
> fet.setGeometry(QgsGeometry.fromPolylineXY(reach)) #reach is a list of
> QgsPointXY
> fet.setAttributes([ str(breakval), brIndex, lenReach])
> Outside for cycle I do:
> But I have always result to False so the feature is not added.
