[QGIS-Developer] Build problems using install instructions
Richard Duivenvoorde
rdmailings at duif.net
Fri Apr 26 03:09:56 PDT 2024
Not sure if it helps, but:
# locate QtWidgetsmod.sip
/usr/lib/python3/dist-packages/PyQt5/bindings/QtWidgets/QtWidgetsmod.sip
# dpkg -S /usr/lib/python3/dist-packages/PyQt5/bindings/QtWidgets/QtWidgetsmod.sip
pyqt5-dev: /usr/lib/python3/dist-packages/PyQt5/bindings/QtWidgets/QtWidgetsmod.sip
Do you have pyqt5-dev installed?
Note:
https://github.com/qgis/QGIS/blob/master/debian/control.in
shows alle packages our Debian packager is using :-)
Else: try to a clean build?
Regards,
On 4/26/24 11:51, Tony Bazeley via QGIS-Developer wrote:
> Thanks Julien,
> I've installed all the packages listed, including pyqt-dev
> dpkg -l | grep pyqt5-dev
> ii *pyqt5-dev* 5.15.10+dfsg-0xneon+22.04+jammy+release+build26 all Development files for PyQt5
> ii *pyqt5-dev*-tools 5.15.10+dfsg-0xneon+22.04+jammy+release+build26 amd64 Development tools for PyQt5
> On Thursday 25 April 2024 10:09:19 PM ACST Julien Cabieces via QGIS-Developer wrote:
> > Hi,
> > You probably need to install the package which provide those files, it's
> > pyqt5-dev on Debian, so it should be the same on Ubuntu.
> > It's on the list of packages to be installed [0], did you install them ?
> > You can check if it's properly installed with the following command:
> > Regards,
> > Julien
> > [0]
> > https://github.com/qgis/QGIS/blob/master/INSTALL.md#33-install-build-depend
> > encies
> > > Hi,
> > > I'm not an experienced builder, and have come to this point after finding
> > > problems with QGIS using KDE Neon - library problems with the binary and
> > > age problems with the flatpack version.
> > > I'm running the latest KDE Neon version which runs on Ubuntu 22.04
> > > I've managed a successful QGIS build parroting instructions from
> > > However this time around I've errors which I don't know how to resolve:
> > > sip-build: /home/tonbaz/dev/cpp/QGIS/build-master/python/core/core.sip:
> > > line 101: column 9: 'QtXml/QtXmlmod.sip' could not be found
> > > /home/tonbaz/dev/cpp/QGIS/build-master/python/core/core.sip: line 102:
> > > column 9: 'QtNetwork/QtNetworkmod.sip' could not be found
> > > /home/tonbaz/dev/cpp/QGIS/build-master/python/core/core.sip: line 103:
> > > column 9: 'QtSql/QtSqlmod.sip' could not be found
> > > /home/tonbaz/dev/cpp/QGIS/build-master/python/core/core.sip: line 105:
> > > column 9: 'QtPrintSupport/QtPrintSupportmod.sip' could not be found
> > > /home/tonbaz/dev/cpp/QGIS/build-master/python/core/core.sip: line 106:
> > > column 9: 'QtWidgets/QtWidgetsmod.sip' could not be found
> > > /home/tonbaz/dev/cpp/QGIS/build-master/python/core/core.sip: line 107:
> > > column 9: 'QtPositioning/QtPositioningmod.sip' could not be found
> > > /home/tonbaz/dev/cpp/QGIS/build-master/python/core/core.sip: line 110:
> > > column 9: 'QtSerialPort/QtSerialPortmod.sip' could not be found
> > > /home/tonbaz/dev/cpp/QGIS/build-master/python/3d/3d.sip: line 8: column
> > > 9: 'QtCore/QtCoremod.sip' could not be found
> > > /home/tonbaz/dev/cpp/QGIS/build-master/python/3d/3d.sip: line 9: column
> > > 9: 'QtGui/QtGuimod.sip' could not be found
> > > /home/tonbaz/dev/cpp/QGIS/build-master/python/3d/3d.sip: line 10: column
> > > /home/tonbaz/dev/cpp/QGIS/build-master/python/analysis/auto_generated/geo
> > > referencing/qgsgcptransformer.sip: line 59: 'throw' is deprecated and will
> > > be removed in SIP v7.0.0
> > > /home/tonbaz/dev/cpp/QGIS/build-master/python/analysis/auto_generated/geor
> > > eferencing/qgsgcptransformer.sip: line 100: 'throw' is deprecated and will
> > > make[2]: *** [python/CMakeFiles/python_module_qgis__3d.dir/build.make:904:
> > > python/3d/build/_3d/sip_3dpart0.cpp] Error 1 make[1]: ***
> > > [CMakeFiles/Makefile2:12031:
> > > python/CMakeFiles/python_module_qgis__3d.dir/all] Error 2 sip-build:
> > > /home/tonbaz/dev/cpp/QGIS/build-master/python/analysis/analysis.sip: line
> > > 6: column 9: 'QtCore/QtCoremod.sip' could not be found
> > > 7: column 9: 'QtGui/QtGuimod.sip' could not be found
> > > 8: column 9: 'QtXml/QtXmlmod.sip' could not be found
> > > /home/tonbaz/dev/cpp/QGIS/build-master/python/core/core.sip: line 101:
> > > column 9: 'QtSerialPort/QtSerialPortmod.sip' could not be found make[2]:
> > > *** [python/CMakeFiles/python_module_qgis__analysis.dir/build.make:915:
> > > python/analysis/build/_analysis/sip_analysispart0.cpp] Error 1
> > > make[1]: *** [CMakeFiles/Makefile2:12084:
> > > python/CMakeFiles/python_module_qgis__analysis.dir/all] Error 2 make: ***
> > > [Makefile:166: all] Error 2
> > > Python sip is installed:
> > > Installed python3-sip-4.19.25+dfsg-3build1.amd64
> > > (manual:ubuntu-jammy-universe) Installed
> > > python3-sipbuild-6.8.3-0xneon+22.04+jammy+release+build12.amd64
> > > (auto:user_jammy-jammy-main)
> > > Any help would be much appreciated
> > > Cheers
> > > Tony
> > > _______________________________________________
> > > QGIS-Developer mailing list
> > > QGIS-Developer at lists.osgeo.org
> > > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
