[QGIS-Developer] Rotating selected features programmatically
Jacky Volpes
jacky.volpes at oslandia.com
Tue Aug 6 07:06:02 PDT 2024
Hi Luke,
> and only rotates the inner most one.
Like I guessed, it's because element_layer_rotated() commits and ends
the edition of the layer (and disconnects signal) as soon as the first
feature geometry has been changed, so all other change won't follow.
Here is a way to wait for every selected feature to be rotated (feel
free to adapt):
def element_layer_rotated(self):
"""When the rotate action is triggered it seems to ignore the
ElementPlacementTool events, so in order to end the edit session
we need to detect a geometryChanged event after the rotation is
complete.
# Do nothing if all the selected features have not been rotated
if set(self.vector_layer.selectedFeatureIds()) !=
set(self.vector_layer.editBuffer().changedGeometries().keys()):
return
QgsMessageLog.logMessage(f"Element Layer Rotated:
{self.vector_layer.name()}", "ElementPlacementTool", Qgis.Info)
# Disconnect from the signal so we can just commit the changes.
self.vector_layer.editBuffer().geometryChanged.disconnect(self.element_layer_rotated)
# Save changes and end edit mode
self.vector_layer.commitChanges()
self.vector_layer.endEditCommand()
self.deactivate()
Regards,
Jacky Volpes
Ingénieur développeur SIG - Oslandia
Le 05/08/2024 à 19:44, Catania, Luke A ERDC-RDE-GRL-VA CIV a écrit :
> So I found that I could use a selectAll() method on the layer directly
> rather than use the processing tool, but when I call the trigger on
> the rotate action it unselects all the features and only rotates the
> inner most one.
> *From:*QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> *On
> Behalf Of *Catania, Luke A ERDC-RDE-GRL-VA CIV via QGIS-Developer
> *Sent:* Monday, August 5, 2024 1:22 PM
> *To:* Jacky Volpes <jacky.volpes at oslandia.com>; 'qgis-developer'
> <qgis-developer at lists.osgeo.org>
> *Subject:* Re: [QGIS-Developer] Rotating selected features
> programmatically
> Well. Now for some reason my select by expression tool is not
> selecting any features, so need to figure out why that is happening
> before implementing this change. I did not make any changes that I can
> see that would have caused this.
> *From:*Jacky Volpes <jacky.volpes at oslandia.com>
> *Sent:* Monday, August 5, 2024 5:14 AM
> *To:* Catania, Luke A ERDC-RDE-GRL-VA CIV
> <Luke.A.Catania at erdc.dren.mil>; 'qgis-developer'
> programmatically
> Hi Luke,
> My guess is that when more than one feature is selected, and the
> rotation is ended, geometryChanged signal is emitted for each rotated
> feature.
> element_layer_rotated() is run when the first geometryChanged signal
> is emitted, and is disconnected, and the layer is saved, and the other
> geometryChanged signals don't trigger anything.
> NB: self.vector_layer.editBuffer().geometryChanged.disconnect() is
> risky, if other slots are connected, prefer
> Regards,
> Jacky Volpes
> Le 01/08/2024 à 20:29, Catania, Luke A ERDC-RDE-GRL-VA CIV a écrit :
> def rotateFeature(self):
> """Find the rotate feature action in QGIS toolbar and
> trigger it so the user can rotate the element.
> # We want to detect when the rotation is complete with a
> geometryChanged signal so we can commit the changes and
> # end the edit session.
> self.vector_layer.editBuffer().geometryChanged.connect(self.element_layer_rotated)
> # Get all actions so we can search for the
> mActionRotateFeature action.
> actions = iface.mainWindow().findChildren(QAction)
> action = [x for x in actions if
> x.objectName()=='mActionRotateFeature'][0]
> expression = '"Element_Nb" = '
> expression = expression + "\'" + f'{self.element_number}'
> QgsMessageLog.logMessage(f"expression: {expression}",
> "StandoffLayers", Qgis.Info)
> processing.run("qgis:selectbyexpression",
> {'INPUT':self.vector_layer,
> 'EXPRESSION': expression,
> 'METHOD':0
> # Inititates rotate feature action allowing to select a
> snap to value.
> action.trigger()
> QgsMessageLog.logMessage(f"Rotate Feature Action
> Triggered", "ElementPlacementTool", Qgis.Info)
> the ElementPlacementTool events, so in order to end the edit session
> rotation is complete.
> changes.
> self.deactivate()
> <mailto:jacky.volpes at oslandia.com>
> *Sent:* Thursday, August 1, 2024 8:26 AM
> <mailto:Luke.A.Catania at erdc.dren.mil>; 'qgis-developer'
> <mailto:qgis-developer at lists.osgeo.org>
> programmatically
> Hi Luke,
> Please provide a PyQGIS code snippet to reproduce. It will be more
> convenient to comment and suggest modifications.
> Thanks,
> Jacky Volpes
> Le 26/07/2024 à 22:06, Catania, Luke A ERDC-RDE-GRL-VA CIV via
> QGIS-Developer a écrit :
> I am using the select by expression tool through python to
> select my features and then I trigger rotation through python
> I see both selected features rotating, but when I click to end
> the rotation, it only rotated one of the features and left the
> other one as is. If I do this through the QGIS using the
> selection by expression in the selection toolbar and the
> rotate in the advanced digitizing tool bar rotating both
> features works fine.
> Any Ideas?
> Luke
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info:Blockedhttps://lists.osgeo.org/mailman/listinfo/qgis-developerBlocked <Blockedhttps://lists.osgeo.org/mailman/listinfo/qgis-developerBlocked>
> Unsubscribe:Blockedhttps://lists.osgeo.org/mailman/listinfo/qgis-developerBlocked <Blockedhttps://lists.osgeo.org/mailman/listinfo/qgis-developerBlocked>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240806/8f6fd73c/attachment-0001.htm>
