[QGIS-Developer] auto sipify and sipify checks on PR
Denis Rouzaud
denis.rouzaud at gmail.com
Tue Aug 13 05:20:45 PDT 2024
Dear list,
There is now an auto-sipify bot running after each push on any active
branches in Github (master + release-*).
We have disabled the requirement for the sip-check test to succeed
(checking that the sip files are up to date) for the PRs.
This means that if you have a trivial change to a header, it is not
strictly required to update the sip files: you can merge and the bot will
update them afterwards.
Just use this with caution as this might lead to merging code which would
make the compilation fail.
Kind regards,
Denis
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240813/649266d0/attachment.htm>
