[QGIS-Developer] qt6-compatible plugins status
Julien Cabieces julien.cabieces at oslandia.com
Tue Aug 20 05:46:57 PDT 2024
There is a plugin metadata which have been added [0] so the Qt 6 QGIS
version would not allow you to load non Qt6 compatible plugin.
Except if you set the variable QGIS_DISABLE_SUPPORTS_QT6_CHECK [1]
And to be complete about that matter, there is a script [2] that help
to migrate a plugin from pyqt5 to pyqt6
Regards,
Julien
[0] https://github.com/qgis/QGIS/pull/55912
[1] https://github.com/qgis/QGIS/pull/56579
[2] https://github.com/qgis/QGIS/blob/bcdf85abb767bdaa967c3eaff433eb43e0a50988/scripts/pyqt5_to_pyqt6/pyqt5_to_pyqt6.py
> Hi, I successfully built and toyed with a qt6 qgis, and I loved it (I'm on fedora). I would love to use it for my day-to-day work, however, I really
> depend on a few plugins for that, and almost no plugin appeared to be compatible with qt6.
> Now I assume that was to be expected, and I don't want to rush any plugin developers, but what I'd love is if there is a way to check qt6
> compatibility for all plugins. Is there an overview page or another way to check which plugins are already compatible with a qt6 build? So that I
> know when again it makes sense to do another qt6 build and try to use that instead of the qt5 build?
> Thanks!
Julien Cabieces
Senior Developer at Oslandia
More information about the QGIS-Developer mailing list
