[QGIS-Developer] qt6-compatible plugins status
Etienne Trimaille etienne.trimaille at gmail.com
Thu Aug 22 05:29:54 PDT 2024
Using the metadata flag on github.com will give you a "quick" overview of
plugins : https://github.com/search?q=supportsQt6&type=code
But this excludes plugins which are hosted on another website.
Side note, is there a readme to know how to compile with Qt6 ? I saw the
flag when compiling, but about required packages for instance ? (Ubuntu
24.04)
Le mer. 21 août 2024 à 10:01, Vincent Schut via QGIS-Developer <
qgis-developer at lists.osgeo.org> a écrit :
> On 20/08/2024 14:46, Julien Cabieces wrote:
> Hi,
> There is a plugin metadata which have been added [0] so the Qt 6 QGIS
> version would not allow you to load non Qt6 compatible plugin.
> Except if you set the variable QGIS_DISABLE_SUPPORTS_QT6_CHECK [1]
> And to be complete about that matter, there is a script [2] that help
> to migrate a plugin from pyqt5 to pyqt6
> Regards,
> Julien
> [0] https://github.com/qgis/QGIS/pull/55912
> [1] https://github.com/qgis/QGIS/pull/56579
> [2] https://github.com/qgis/QGIS/blob/bcdf85abb767bdaa967c3eaff433eb43e0a50988/scripts/pyqt5_to_pyqt6/pyqt5_to_pyqt6.py
> Thanks Julien, I'll try the QGIS_DISABLE_SUPPORTS_QT6_CHECK variable to
> see if the plugins that I depend on actually work.
> Hi, I successfully built and toyed with a qt6 qgis, and I loved it (I'm on fedora). I would love to use it for my day-to-day work, however, I really
> depend on a few plugins for that, and almost no plugin appeared to be compatible with qt6.
> Now I assume that was to be expected, and I don't want to rush any plugin developers, but what I'd love is if there is a way to check qt6
> compatibility for all plugins. Is there an overview page or another way to check which plugins are already compatible with a qt6 build? So that I
> know when again it makes sense to do another qt6 build and try to use that instead of the qt5 build?
> Thanks!
> Vincent Schut
> Remote Sensing Software Engineer
> +31 302272679 ~ Maliebaan 22 | 3581CP | Utrecht | Netherlands
> Linkedin <https://www.linkedin.com/company/satelligence/> ~
> satelligence.com <http://www.satelligence.com>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20240822/1f3606d8/attachment.htm>
More information about the QGIS-Developer mailing list
